Like Tree25Likes
Old 02-03-2015, 12:33 PM   #1666
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by tonybod View Post
I tend to use brake more to avoid smashing into the rear of someone else
Thanks again for the setup, the car felt as good as my M05 last night. Really easy to drive.
Just hit them so they learn to get out of the way lol. Damn FWD cars.
What sort of surface are you running on? I use the ball diff in mine.. I have yet to rebuild it.. It's going on 3 years lol.. That's the beauty of a 21.5, doesn't put much wear on the diff
Raman is offline   Reply With Quote
Old 02-03-2015, 12:37 PM   #1667
Running on carpet.
Is it the TA-05 ball diff you run?
tonybod is offline   Reply With Quote
Old 02-03-2015, 12:48 PM   #1668
Raman's Avatar
M05 ball diff
http://www.tamiyausa.com/product/item.php?product-id=54194
Old 02-09-2015, 03:47 AM   #1669
gcooper's Avatar
Raman,
Are you running 0-rings in top of shocks bladders? if so how many F/R.
Are your springs the long ones or the shorties?
Thanks,
Coop
I`ve had lines on my face since I was twenty. Wind and sun put them there.
If you asked me if I`m the luckiest guy in the world, all I can say is `yup`.
Tamiya 41something - Ko Propo - Tekin RS Pro/BL check!
gcooper is offline   Reply With Quote
Old 03-02-2015, 07:39 PM   #1670
Trader Rating: 18 (100%+)
I've decided to join the m-chassis club! I am awaiting a used M-06 to arrive with some alloy upgrades. I don't think there is any races locally but I have plans to just have fun with it, maybe try to turn it into a little drifter. I have a Tekin RS Pro Spec & 13.5t planned for power. Does anyone know if the colt bodies from rcmart fit the chassis? Specifically the old school pickup here http://www.rcmart.com/colt-m2318-min...?cPath=438_874
Looking forward to owning one of these darts!
recoverytrouble is offline   Reply With Quote
Old 03-27-2015, 06:48 AM   #1671
crazy nick's Avatar
Trader Rating: 20 (100%+)
Anyone ever mount the rc4wd steel wagon wheels on an m06? I'm wanting to use these with the stock tamiya tires for a blackfoot body m06 build I'm doing.
Rcjuice.com
Hobbystar
"I use the tears of the people I hack to sauce my tires!"
- Chris Kline
crazy nick is offline   Reply With Quote
Old 03-27-2015, 01:31 PM   #1672
Raman's Avatar
Originally Posted by gcooper View Post
Raman,
Thanks,
Coop
Sorry coop, only seeing this now. No I don't use the o ring on top of bladders. No one uses those anymore. They create more rebound.
When you can, check out Jiles Grosskamps trf416 build tips on YouTube. I build my shocks the way he does and they come out amazingly consistent
Old 03-27-2015, 01:33 PM   #1673
Raman's Avatar
Any body that has a rear trunk will work on M06. Bodies that hatchbacks will not work
Old 04-10-2015, 05:29 AM   #1674
I've just dug out my old M06 and would like a ballpark set up for the TRF shocks please. Am I correct in thinking the rear shocks should be longer than 56.5mm?
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 04-11-2015, 03:20 PM   #1675
Raman's Avatar
Which TRF shocks are you running? TC or m chassis?
Old 04-12-2015, 03:11 AM   #1676
M chassis. I've set the fronts at 56.5mm using an o ring, the rears I took out the o ring so it has some droop. Might struggle to get 5mm ride height on the rear using M chassis springs.
Old 04-16-2015, 12:11 PM   #1677
Raman's Avatar
The Pro kit came with 9805504 piston shaft which is slightly longer. You would have to special order it from Banzai in Japan. Otherwise, you can use a TC piston shaft, to give you more ride height.
On my car, I'm actually running the TC damper on the rear, because I have the R spec lower suspension mount, which even lowers / lengthens the mount.. So the M chassis damper was coming up short.
Old 04-17-2015, 02:38 AM   #1678
Any idea what length the rear shocks are end to end when built?
Old 04-17-2015, 12:45 PM   #1679
Raman's Avatar
Send me a PM later today, that way I'll remember when I get home tonight to measure them for you.
Old 04-19-2015, 11:06 AM   #1680
Herc Driver's Avatar
Anybody have an opinion on 1 degree vs 2 degree rear hub carriers?
Also, I've noticed the front graphite shock towers (among other parts) is discontinued...any insight to this?
I missed the boat with the M06 pro...now I'm piecing one together slowly and $$$$.
Herc Driver is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21196 Yesterday 11:56 AM
EAMotorsports discussion thread BigDogRacing Team and Company Discussions 7672 10-11-2017 10:51 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
