TAMIYA M-06 Thread
#1491
hey , i have my m06 , that ill be running on med grip carpet , can anyone suggest a good starting set up , running m-chassis trf's , also have a 3racing gear diff , it has a 21.5t motor and a bit of timing ..
i'd appreciate any help ..
#1492
This what I run
60wt / yellow fr, 60wt / blue rear. Gear diff, I will let someone else chime in since I run ball diff. Ride height 5 mm rear and 4 mm front. I also run 1 degree rear up rights, camber - 2 in rear and front 0 degree. I also run with zero toe out in front
#1493
I ran these tires this weekend on a medium to low grip carpet and they hooked up well. I ran the mediums in the front and the softs in the rear with hard inserts in both.
http://www.tqrcracing.com/shop/produ....asp?p_id=1849
http://www.tqrcracing.com/shop/produ....asp?p_id=1848
#1494
#1495
ok thanks for your help , last question , can you remember what pistons that was ? ive had 2 mo6's before , last one was dialled , just can't remember my set up from it .. thanks again
#1497
ok thanks , last question !! shock lenghs ??
i ran the car tonight , it was ok , found it a bit inconsistent , played about with springs , it either was spot on , understeer , or grip roll !!
, however i did find a problem with the front shock tower ( it was loose ) , that will proburly exsplain why it would digg in the spool the diff up !! will change the pistons for next week ..
#1498
You may want to watch this video. It has some setup tips.
http://www.youtube.com/watch?v=ANzz-xIgX4c
#1499
I raced again last night against the field of 1/18. The same 2 fast guys held 1st and 2nd and I consistently was 3rd. I worked on increasing my confidence with corner speeds and smoother transition in the infield. It's starting to pay off.
We race on asphalt and yesterday was super windy as well.. Nonetheless I had very consistent traction.. Not bad for a RWD!
#1500
Dusted off my m06 for a run yesterday and was very happy with where I got the car to.
Qualified 3rd, finished 2nd. Only 06 in a field of 05s. Medium outdoor, boral asphalt paint.
Mid wheel base, Ride BRZ body. Standard battery, reward position.
Ride SC32 rear, and MC34 front all on inch up rims.
Yellow front spring blue rear, 60wt oil front and rear. 3 hole pistons. Option rear damper stay, outward mounting position, standard lower arm mounting.
1.5 rear toe.
Ball diff, alloy rear stiffeners and lower front plate are the only other hop ups.
The car was really good on this setup, still hunting for a little more on power steering, but it's very close.
1.5 rear toe.
