Old 04-07-2002, 12:33 AM   #1
Default someone with a quantum help me!
hi all, i got a quantum pro sport speedo, it has a small pot on the top to adjust the traction control.
according to the manual, no matter what setting i have this on, the top speed of the car will not be affected. however it blatantly does, when i have it turned way down at the minus sign.
i'm just wondering if this is a problem with my speedo or an inherent characteristic of the speedo itself. i've posted around but nobody even replies (NOT EVEN LRP)
have a ncie day
schumacher is offline   Reply With Quote
Old 04-08-2002, 10:40 AM   #2
darnold's Avatar
Schuey- Try re-setting the speedo but this time with the pot turned down all the way. I am not sure what the directions say but it may be that when you initially set it you are to have the current limiter turned down. It should be that the current limiter affects your accelleration giving you more or less bottom and possibly mid-range torque. Also, re-check the settings of your transmitter before you re-set the speedo to make sure that they are the same as the instructions say For Your Transmitter. If you accidently used the wrong Transmitter Settings then that would also cause some problems potentially. LRP probably will take about a week to get back to you but they will do so. If the above info doesn't help you can get in touch with Team Associated for advice via their website or you can Call them and talk with them immediately (numbe is on their website). Also if your LRP comes with the new LifeTime Warranty card you can get it replaced if for some strange reason it's defective and or if it's still in regular warranty if it doesn't have the Lifetime warranty. Talk to Team Associated to see. Hope this Helps- Dave A.
darnold is offline   Reply With Quote
Old 04-08-2002, 12:04 PM   #3
Regional Moderator
daniz24's Avatar
Quantum + any 7 Turn Motor + High timing rate = Fire + Smoke - Credit Card Limits LOL
daniz24 is offline   Reply With Quote
LRP Speed Controllers! Quantum Sport and Quantum Comp. WhoMe R/C Items: For Sale/Trade 13 03-15-2007 04:26 AM
LRP Quantum & Quantum 2 Speed Controls Fabulous R/C Items: For Sale/Trade 8 03-30-2006 10:45 PM
LRP Quantum or Quantum 2 competition Core Creations R/C Items: Wanted to Buy 1 10-03-2005 10:56 AM
MF2 - XXX G+ - Quantum 2 Tacoma R/C Items: For Sale/Trade 15 06-05-2005 05:11 PM
Need help with LRP Quantum 2 MrRolla Australian Racing 3 09-05-2004 04:46 PM
SEO by vBSEO 3.5.0
