Endurance Motor
#16
Originally posted by tornado
How long is the race ...may I ask?
#17
the spray i think is video head cleaner, that what we do to cool down caburator for GP during race, EP seldom cos no endurance. but for small race where 20 ppl joint just 5-10 have to start next round we used to spray on the motor can *not directly on the comm experience the comm came off just after the spray. extreme hot and extreme cold the glue to hole the 3 piece comm fail.
#18
Guest
Originally posted by ritchie
no nothing special was done this year, one guy ran a heat sink this year, last year one had a can of something, he would spray on the motor while the battery was being changed, it cooled the motor, i want to say it was fe - on, but don't think that was what it was. this thread is new and i'm sure others will respond shortly with more info,
#19
Guest
#20
yah have to spray from a distance.. but during race ur pit boy sure hit it direct into the motor not around the motor
#21
I have run two enduro races. One race was at the Tri-Clone, and the second at S&N Trackside. The winners of both events drove their cars just like a 5 min race, basically a sprint race. They were faster; our slightly slower strategy was no match for them. All said and done, just build the motor just like you would for a normal race. However as everyone has said, gearing is critical. I hope this little insight helps.
#22
back to the main topic
any motor will do just bare in mind that the ratio and bearing is the main / most important thing
#23
#24
Guest
#25
wounder if IFMAR organise endurance for EP sure more info. will be publish on mag. and see which EP driver are more consistant.
#26
Guest
Originally posted by Entropy
Would you happen to know what motors they were using??
If you have a chance ...check out the 24hrs enduro in the Europe. Learn a lot from them.
#27
if there is an endurance race i think i'll go for 8T with lighter ratio where i can achive 8 minutes for 3300
#28
Guest
#29
Guest
I've seen one boy burn his speedo using 8T. He ran for 'bout half an hour or so and his QC2 decided to give up. He lost 'bout 15 min. before heading to tracks again.
#30
More info more info!!!
