Esc Capacitors
#31
Overkill in the size is quite common as it seems. However the type of the capacitor is much more important. It should be a high frequency or a low-impedance capacitor. Changing to a huge capacitor of the wrong type can be a step to worse from the stock capacitor.
On the other hand, no capacitor will make you win races.
#33
I got my dyno to completion and I made a few test with caps. Instead of the normal power supply I used a speedo and an old blue Panasonic 3000, because of it's high internal resistance. The motor used is a 13x3 Corally. I dyno tested the power got out of the motor with three power level settings that approximately match 1/3, 2/3 and full throttle. All measurements were done with and without a cap. The cap used was what I normally use, Rubicon ZL 4700 uF. The ZL series was the best I could find a year ago.
From the results it can be seen that the improvement is massive on partial throttle, especially close to the 50% pulse width. At full throttle no difference was noticed. I also set the motor to run with a constant low speed and swithced the cap on and off. The power incresed and decreased accordingly. I hope I have proved my point now.
Best regards, JesseT
#34
are the1/3 power lines labelled the right way round?
According to your graph 1/3 throtttle is better without the cap.
2/3 throttle shows an improvement with the cap.
If the graph is labelled right then 50% throttle would give little to no difference in performance.
#35
Yep, they are labeled wrong. I'll fix it...
Corrected...
Corrected...
#36
JesseT & dw:
Thanks for the info. Can you clarify some stuff for a newbie. I know little about electric cars, I am a ME not an EE
My experance stems from a HPI pro I had years ago. ran a midnight 2 motor that I had to solder 3 cap to. I have a Quantum competition in the car using a green machine 3. This has the caps already in the end bell. Do I need to solder the caps that came with the controller to the motor???
Thanks for any help.
#38
RCCadet:
Sorry, no. I don't have a single stock motor. A guess the effect is pretty much the same, for the exception that stock class racing is done pretty much using only full throttle, and this is where the capacitor of the ESC plays of no role.
RC Nitro:
Don't confuse the ESC capacitor we are talkin about in here to the capacitors that are on the motor. The motor capacitors are to eliminate radio interference created by the motor. These are very much needed for proper operation, but the type of them is not crucial. If your motor already has capacitors, you're fine. They don't need to be the ones that were supplied with your ESC.
RC Nitro:
#40
Originally posted by JesseT
RC Nitro:
RC Nitro:
I did, thanks very much for the clarification and the info!!
#41
Schottky diode
Would soldering the schottky diode on my Cyclone to the soldering post be the same as soldering the the diode to the endbell? Would this hurt performance of the ESC or motor?
#43
Originally posted by Geetoo
I had a mistake in soldering my schottky diode to the motor with wrong polarity. I noticed everything went wrong but had a few laps with it. Will this damage the ecs and motor?
Yung motor mo, walang kaso yan! slave lang ng ESC yung motor eh... ayos lang yan! sige, ulitin mo, tingnan mo, hindi masisira ang ESC mo at Motor mo... dali ulitin mo!
#44
geetoo: in my case, i also soldered the diode backwards. after pulling the throttle, the motor ran slowly then the diode started to burn up and crack open. after removing the diode, everything worked fine. i dont think this will damage the motor and esc.
