Old 08-06-2010, 07:17 PM   #1
Default suspention blocks question
Hi there
What the idea behind changing suspension blocks to change toe angle ??
Isnt it easier just to adjust the turnbuckles instead ??
inboard / outboard toe: does it make any difference which one is adjusted ??
1101 is offline   Reply With Quote
Old 08-06-2010, 07:24 PM   #2
Essnowyt's Avatar
Send a message via AIM to Essnowyt
On modern touring cars, the turnbuckle changes camber. The block changes you referenced are related to the suspension arm toe in/out.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 08-07-2010, 04:17 PM   #3
RLMW VQ's Avatar
the blocks are for arm sweep you can run arm sweep which can how the car conners. lets say you run hpi 0 fr and 1ff you would have one deg. of arm sweep then you set the toe you what you want. this is for the front, on the rear the blocks do control the toe. you should check the hotbodies cyclone thread and look for koreys arm sweep post. but it is something to try and play with. the same concept is ture for tamyia. also changing the front block can also change the front track width. but front block should not be used as toe adjustments those should be made with the turnbuckles.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45126 Today 03:08 PM
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
SEO by vBSEO 3.5.0
