Old 08-01-2010, 11:10 AM   #1
racing_jason's Avatar
Default Flappers?
I dont know if this is the correct place to put this, but i was wondering what material some of the tracks use for flappers? as of now we have dishes but our track is on the tight side and when you hit these dishes it makes for alot of breaking. So we were looking to go to flappers to maybe save our selfs on parts.
Thanks Jason Hunt
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 08-01-2010, 11:13 AM   #2
wingracer's Avatar
Trader Rating: 21 (100%+)
Kydex. Find a plastic warehouse in your area and they should have it in sheets. Many will even cut it for you.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Old 08-01-2010, 12:23 PM   #3
Regional Moderator
CarbonJoe's Avatar
We use 1/4 inch thick UHMW (Ultra High Molecular Weight) plastic. The stuff is insanely expensive, but almost indestructible. A 0.250 inch thick 4x8 sheet is around $166, 3/8" thick is $256, and 1/2" thick is $370. We ripped it to 4" x 96" strips to use for flappers. We tried exterior vinyl molding from Home Depot, but the drywall screws eventually pull through. It doesn't happen with the UHMW plastic.
The UHMW flappers are very easy on the cars.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
SEO by vBSEO 3.5.0
