MurfDogg Synergy Brushless Motors
#123
Why would anyone run negative timing unless you're using reverse rotation on purpose.
When timing was introduced on brushless motors, I instantly thought about the good old days tweaking brushed motors.
Can you provide some dyno readout for the 13.5, 17.5?
#124
With boosted esc's, you usually want little or no motor timing and use the esc's boost and/or turbo functions to get the timing you want.
#126
I can provide Dyno numbers. However, unless you use the CE Turbo Dyno like I do, and run it at the same settings I use in a controlled environment, the Dyno Sheet will not tell you much. It will look like a piece of paper with numbers that you have no reference to. I do not use the Fantom Dyno which bases its numbers off RPM and Amp draw. My dyno gives the motor a true load, which is the only way to actually Dyno a motor with usable results.
What kind of useful info are you looking for? I would be more than happy to do what I can to help you with whatever you are trying find out about these motors.
Matt
#131
Stock Update
17.5 and 13.5 motors are out of stock. I have another batch on the way, and am hoping they are here end of the week... fingers are crossed. 10.5, I only have 1 or 2 left right now. 4.0, 4.5, 5.5, 6.5 turn Mods are in stock and ready to ship.
Thanks for all of the Support guys!
Matt
Matt
