MurfDogg Synergy Brushless Motors
#181
17.5 motor
I just received a 17.5 1C spec Murfdogg brushless motor to run in 12th scale, and I've had nothing but problems with this motor.
It stalls from a dead stop, coggs and is way slow. I changed sensor wires, reduced "boost and turbo" settings on my Tekin ESC and changed gearing to try to fix the problem. I did not change the timing on the motor either.
All my other 17.5 motors from Trinity, ORCA and Speed Passion run strong with no problems.
Is there anything else I can do to fix this problem? or do I have a $100 dollar paper weight.
Greg G
Greg G
#182
Greg G
Greg G
#188
No plans on production 21.5 motors yet... just starting to build some prototypes.
Please do not be so negative Greg.... I hope that if anyone has any issues with my products, that they contact me directly instead of posting questions about their new $100 paperweight.
Sounds like a hall sensor went out. It happens.... with all brands of motors.
Send it in to me so I can diagnose the problem.
ABSOLUTELY
Matt
Greg G
Greg G
ABSOLUTELY
Matt
#189
New Products!
MurfDogg Racing is proud to announce a new addition to its race winning line of products:
Ceramic Bearing Sets and Silicon Nitride Diff Ball Sets!
Part # Description Price
CBS-12 - Ceramic Bearing Set for Pan Cars with 1/8" Front Axles $44.99
CBS-13 - Ceramic Bearing Set for Pan Cars with 3/16" Front Axles $44.99
CBS-11 - Ceramic Bearing Set for MurfDogg Synergy Brushless Motors $10.00
CBS-10 - Ceramic Bearing Set for Custom Works Dirt Oval Cars $69.99
CBS-14 - Silicon Nitride Diff Balls - 1/8" for Pan Cars (12) $10.00
CBS-15 - Silicon Nitride Diff and Thrust Balls for Dirt Oval Cars and $15.00
All Team Associated Ball Diffs (12 - 3/32" and 6 - 5/64")
Each Silicon Nitride Ball is precision ground to the tightest tolerances possible, ensuring you the hardest, smoothest, roundest ball you have ever used. You want a SMOOTH Differential, these balls are your answer!
#191
Greg G
Greg G
Received your motor today, hooked it up to the magical motor machine, which told me that the sensor board was bad. Replaced it, hooked her up to the machine again, and all 3 sensors were firing correctly. I put her on the dyno, and she sang! I packaged her back up, and she is ready to rock!
ALL PM's REPLIED
Matt
#195
Trader Rating: 25 (100%+)
Matt's a good guy that stands behind his products!!
And now he's got STEEL BALLS TOO!!!
