hyperion s0606i charger prblm
k guys i have a hyperion charger and it has work great for 2 years now but the other day at the track i went to charge my lipo and it came up on screen "output circuit problem" every now and then it will act like its charging but i dont think it is. but it comes on the screen output circuit problem every time.. what is the issue anyone else with same charger have this issue?
Are you using it with the balancing board? I had a similar problem with my 720i. I was getting some output error message and a lot of beeping. Turned out I had a bad connection on the red balancing board wire. Soldered it back and it worked fine again.
