Mixing Silicone Oil
Mixing Silicone Oil
I wanted to know if there is a formula for mixing oils.
Say if i had 1000wt diff oil & 5000wt diff oil and i mixed them what other wt's could i get, and what amount of each would i need to get what numbers. any help would be good, thanks
I am wanting around 2000wt if posible.
the reason is i wanted to try it out tomorow, and no one local to me has it.
http://www.gelest.com/company/pdfs/siliconefluids.pdf
Page 26 will show you a chart and formula. 2000 cst is pretty widely used, Kyosho, Mugen, Xceed, Serpent, and Xray all sell it.
That is a frickin' rad post! I have never though of mixing oils to get different weights of oils... !
The only thing you ahve to check, is "weight" is not a linear scale, and varies between manufacturers. "cst" is a linear scale and would be the ideal choice for mixing proportions, e.g. 50/50 mix of 1000cst and 3000cst will give you 2000cst.
