Just got the Yok CGM
This car is awesome to drive and most of the stuff that needs to be checked is pretty easy to get to. I am looking for aftermarket parts for this vehicle. Does anyone have any ideas? I know of Rayspeed, but there site is in Asian, any other ideas would help.
Thanks for the help
Thanks for the help
Guest
Yoks owners are converting their SSG or black special to CGM due to the CGM's chassis stiffness.
Rayspeed would a list of other upgrade parts for da SD ....being chassis (making it look like black special), centre shaft, etc....gotta check around.
Re: Just got the Yok CGM
Thanks for the help
Thanks for the help
I just abit concern the weight of the CGM
shansrote -
Can you tell me how much weight for your CGM when ready to run? thanks
shansrote -
Car is great and handles well with tons of tuning options. Keep an eye on the plastic shaft drive cups, they break and bend. Go with the Team Suzuki stuff on the Yok web site, expensive though. The aluminum cups are great, but I think they might be discontinued.
Guest
Guest
shansrote -
shansrote -
You should post your question to the Yokomo thread...
I would recommend replacing the front and rear input shafts with Titanium units made by Square. Or you could use the Aluminum units made by Yokomo.
A pair of the Ti units, weigh less than one of the shafts included in the kit. If you want to lighten the car, starting with the drive train is a excellent way to lighten the car, and imporve accelleration.
By using Ti-screws and Shooter Graphite Shaft my weight landed on around 1520-1530 with personal transponder. And now with the most tranny parts in lightweight shape it is around 1490-1500 with personal transponder.
btw, i've tried several driveshafts, YMP Greens, Yokomo Blue alu and some ones i got from a friend who did'nt know what they were..
The YMP's hold up real well in modified with rubber and oneway IN REAR. In the front they twisted real bad, so i run them in rear only for now..
The "unknown" (bluegreen color) twisted like hell both in front and rear, not good
Yokomos hold up really well. I've broken one but that was in a BAD crash right into the boards in full speed that would bend up everything...
My current setup is YMP in rear and Yokomos with Square Ti output shafts (Yokomo is steel, heavy )
I've ordered Square Ti complete axles to try, my pal uses them with no twist at all..
Yokomo did (not sure if they still do) make good aluminum drive cups, but when I ordered, the Team Suzuki ones were available (they are milled down for weight) and they work great. As far as the shaft, the carbon fiber Yokomo one twists, but is much lighter. I actually had a big TC3 carbon fiber shaft cut down and reglued to the right size and it worked awesome till it failed. I'll probably try it again, it held up for about 6 weekends of racing.
