Turbo 35 GFX Problem
Hi,
I had an problem with my charger ( CE GFX ) .
My problem is when i am in the charge mode, disharge mode cycle and motor. The second line of the screen is illegilbe. It's not letters or numbers, it's symbol. And on the last mode ( save load etc ) i'm block in, the rotary dial not answer and i do switch off my power supply for restart in the first menu. And when i switch off the power, i had not the last sentece ( bad power...... ) It's very strange and i am very .
What do you think of this?
Thanks for your answer.
Yann.
Yann.
Hi yann,
Problems occurs after Sunday at Emerainville ??
Not a fuse problem ??
Stephane Magnier
New Owner of a 415 !!!
I'll need you for setup sheets ...
Stephane Magnier
Hi, ok thanks a lot for your answers.
I go contact CE for more info. But i prefer send a mail. Because i don't speak very well
Wiget, yeap it's right. Not a fuse a problem i had change all. And same result. One fuse it's for power supply and two for batteries.
Thank
Yann.
Thank
Yann.
Ok Tres, Thanks a lot.
Yann.
Yann.
Hi, it's ok now,
i had receive an mail from Jim Bailey.
You can reset the memory by holding down the PAGE button during power up until you see the message: SYSTEM INIT.
And it's ok now, i'm so happy.
Thanks all.
Yann
Thanks all.
Yann
