Old 06-01-2004, 05:52 PM   #286
SCIDA's Avatar
Try using very stiff springs, along with cutting a plus into the positive brush and a vertical line on the negative brush. I heard people calling this the polarity brush set up. For the best result use:
PEAK-PEK2229 Serrated Pro Stock Brush - Sprint Brushes
PEAK- PEK2053 150' Viper Stock Spring Negative
PEK2054 175' Viper Stock Spring Positive
SCIDA is offline   Reply With Quote
Old 06-01-2004, 10:11 PM   #287
over gear's Avatar
Trader Rating: 15 (100%+)
I have 767 with the stock springs on my 19T motor. Gear at 5.88 and 6.19 on my TRF415. There is no binding on the drivetrain and i am using brand new battery. There is no punch at all.
does stiffer springs play a major role on the Reedy 19T?
over gear is offline   Reply With Quote
Old 06-01-2004, 10:21 PM   #288
SpeedTech's Avatar
767 worked pretty good, but I think 4499 E brush were better. We ran stiffer springs as well, anywhere from 10oz and up to around 11.4 oz according to our spring dyno. Also, gear it to the moon, on the cool time of the days, we were geared at 5.79 on the Barracuda and 5.9 when it heat up.
Stock spring on the Reedy 19T varies anywhere from 8 to 8.5 oz.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-01-2004, 10:23 PM   #289
Well as you know , stiffer springs will give you more torq. but will also ad drag when off throttle .. try to reset your speedo for throttle if its been a while .. I run C2 19t. and found them to have alot of power , but never could get a REEDY19t to have the power i needed...
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-01-2004, 10:24 PM   #290
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
what about the Chameleon 2? i have been looking for dome info on this one, too. trying to get ready for GT1...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-01-2004, 10:35 PM   #291
This is the way I set up the TQ's motor(EJ Evans).......
Reedy 766 brushes......on the positve side it was a plus cut(vertical and horizonal)......on the negitive side just a vertical slot(polarity brushes I call them...plus and minus)...Blackstock and I came up with this set up at the Novak race....
Reedy copper head springs bent to 180 degees both sides works the best...
hope that helps all of you,
Barry
Barry Baker is offline   Reply With Quote
Old 06-01-2004, 10:39 PM   #292
mcmoney's Avatar
Barry what up sucka
mcmoney is offline   Reply With Quote
Old 06-01-2004, 10:39 PM   #293
Turbonium's Avatar
thanks Barry! ill grab me one od those reedy 19s and get to tuning...
Wes
Team Novak
Old 06-02-2004, 04:55 AM   #294
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Barry,
Could you please post your setup from the Reedy race.
mike ivy is offline   Reply With Quote
Old 06-02-2004, 05:27 AM   #295
s2
s2's Avatar
At the risk of sounding dumb; which Reedy 19t was the spec motor? the original silver can 19t spec, or the newer quad mag, flame can design?
s2 is offline   Reply With Quote
Old 06-02-2004, 05:30 AM   #296
s2
s2's Avatar
Barry
What tool did you use to make the slots?
cheers
Stew
Old 06-02-2004, 05:38 AM   #297
Timmy_G's Avatar
Send a message via MSN to Timmy_G
anyone have any vid's from the reedy race?
thanks
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 06-02-2004, 06:13 AM   #298
rocketron's Avatar
Trader Rating: 16 (100%+)
new 19t quad with the flames was the spec motor
rocketron is offline   Reply With Quote
Old 06-02-2004, 08:47 AM   #299
I did tweak the springs to get more pressure
DOTMAN is offline   Reply With Quote
Old 06-02-2004, 09:00 AM   #300
thanks
Yeah, I'll second this. Seems like there was a lot more footage last year.....I know futureal is settling in, so is there any other place or source that has video?
aviaar is offline   Reply With Quote
R/C Tech LIVE at the 2005 Reedy Race of Champions @ Tamiya USA speedxl Electric On-Road 1045 07-18-2005 07:12 PM
Reedy Race of Champions 2004 Windtalkers Malaysian R/C Racers 7 06-11-2004 09:53 PM
Reedy Race Of Champions 2004 ROBORAT Electric On-Road 6 05-26-2004 09:12 AM
Reedy Race of Champions 2004 glide 1 Electric On-Road 2 05-06-2004 10:01 PM
R/C Tech Live @ the 2004 Winterfest U.S. Triple Crown Race in Milwaukee, WI futureal Electric On-Road 52 03-02-2004 07:30 PM
