Old 05-28-2004, 06:23 PM   #16
Send a message via AIM to rcguy2477
I dont know if this idea would work, but couldnt you tape them in? In my head it seams feasible, but i am not sure if it will work.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 05-28-2004, 07:23 PM   #17
fatdoggy's Avatar
R/C Tech Charter Subscriber
1500mah batt, mabuchi motor... The racing in the class is obviously going to be very close so you'd need every little bit to have an advantage. If you make your packs into saddles you will be able to equalize your cells, important for nicd's. If your so set on stick packs just buy a car that will let you run them.
fatdoggy is offline   Reply With Quote
Old 05-28-2004, 07:52 PM   #18
Send a message via AIM to True R/C Racing
Buy a Used Graphite chassis.... You can get them real cheap.
True R/C Racing is offline   Reply With Quote
Quick M11 question Rival Radio and Electronics 4 03-24-2008 09:46 PM
Quick Question csalfly Electric On-Road 6 05-06-2007 09:18 AM
Quick TCS question Turbo Joe Electric On-Road 6 05-31-2004 12:26 AM
Quick question? lazarus Electric On-Road 3 03-17-2004 11:13 AM
SEO by vBSEO 3.5.0
