Like Tree1Likes
Old 01-13-2011, 02:11 PM   #1441
Rick Hohwart's Avatar
Originally Posted by M.Abramowicz View Post
At Christer setup is 5mm shim for rear outer ball, maybe 2? not 5?
Regards!
m
The setup he gave me showed 5mm.
Rick Hohwart is offline   Reply With Quote
Old 01-13-2011, 02:28 PM   #1442
C.Andersson's Avatar
Yes I am running 5mm in the rear hubs.
Team Associated - Reedy - LRP - Sanwa - ProtoForm - Capricorn Rc
C.Andersson is offline   Reply With Quote
Old 01-13-2011, 02:35 PM   #1443
What weight oil is everyone running in their gear diffs? Front and rear.
franc furter is offline   Reply With Quote
Old 01-14-2011, 05:44 AM   #1444
Strange and high!
Why?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-14-2011, 06:19 AM   #1445
mugenize1's Avatar
Default Parma Foams
Can someone tell me some info on Parma foams wheels. I would like a set for my TC6 for carpet racing I found some sets.
Magenta = 35
Purple = 40
Now here is where I am lost what do they mean by these sets
Cyan = 35/55
Plaid = 40/55
What do they mean by this 35/55 40/55
mugenize1 is offline   Reply With Quote
Old 01-14-2011, 06:23 AM   #1446
100.000 front
1000 back
greetings
thilo-alexander is offline   Reply With Quote
Old 01-14-2011, 07:13 AM   #1447
Strange and high!
Why?
Running the links high from rear hubs forces the rear make more 'work' which means that the rear roll more. The car is more reactive when coming inside the corner. This is a good way to balance front and rear
But you know setup is one combination with some compromises
Old 01-14-2011, 08:23 AM   #1448
It was not included on the sheet, but Juho ran AE 50wt. oil
Strange and high!
Why?
It works for him. If you notice he also uses very little toe-in in the rear.
Old 01-14-2011, 08:29 AM   #1449
cyan and plaid have a harder outer ring, dual compound like jaco double pink orange
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 01-14-2011, 08:35 AM   #1450
-showtime-'s Avatar
Magenta = 35
Purple = 40
Cyan = 35/55
Plaid = 40/55
Those are dual compound tires. The Cyan is magenta (35) with a thin ring of orange (55) around the outside and the Plaid is purple (40) with an orange ring (55). We used to use these on the front to keep the car from digging in the middle of the corner.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 01-14-2011, 10:52 AM   #1451
S_fender's Avatar
Hi Christer,
What outer ball are you running ? Short or long Neck ?
And i don't understand the diff's notes ("measure 1.6 g gear diff oil").
Thank you for all the informations.
S. Fender.
S_fender is offline   Reply With Quote
Old 01-14-2011, 11:47 AM   #1452
Mr.Che's Avatar
@ S fender Fill quantity in weight for the diff = 1.6 gr
For more Setups http://nfc-racing.ch/blog/setups/tc6/
Team LRP / AE
Mr.Che is offline   Reply With Quote
Old 01-14-2011, 12:05 PM   #1453
Mowell's Avatar
Hey guys I'm having an issue with my tc6. My car seems really sensitive to seams and grooves wear in the carpet at the places I'm running. When I hit these spots it grabs my car. I'm a noob when it comes to non off road applications.
Most of my setup is around factory set up, but I've gone with negative toe to see if I could get my steering to center. Its so hard to run consistent when my car won't track straight. I can't trim out the problem, and I've tried numerous sets of tires (sorex 24,28, tamiya spec slicks, radios, servos just to make sure it wasn't the problem. The problem disappears on road surfaces. Whenever it hits a seam or wierd spot in carpets my car follows.
Any help or advice would be appreciated.
I must have some alignment differences too, I'll double check once I get access to a nice alignment table.
TC6, Ten SCTE, Novak, Fantom, Savox, Spektrum
Mowell is offline   Reply With Quote
Old 01-14-2011, 01:27 PM   #1454
Make sure your servo saver is plenty tight.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 01-14-2011, 06:00 PM   #1455
Maybell's Avatar
Default Carpet Grain
Im not saying this is the problem your having for sure, but have you tried driving a friends car to see if the same thing happens. The direction of the carpets grain affects how a car tracks. In other words, the grain of the carpet can make your car seem like its tracking to the right on one part of the track, but to the left on another part. It seems cars never track absolutely perfect on carpet, especially rubber tire cars.
I hope this might help!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
