Like Tree1Likes
Old 01-05-2011, 08:39 PM   #1351
Originally Posted by TJames987 View Post
I just attached all of the camber links to the chassis and everything is bound up so tight it can hardly move.
For the pros out there how do you free this thing up?
I think you did something wrong. You didn't spray the car with WD40 again?
M3dreamin2008 is offline   Reply With Quote
Old 01-05-2011, 09:08 PM   #1352
STLNLST's Avatar
Trader Rating: 19 (100%+)
I hope the 2nd batch is issue free
STLNLST is offline   Reply With Quote
Old 01-05-2011, 09:16 PM   #1353
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Mine from the first batch was fine man. Went together with no issues All parts were there
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-05-2011, 09:18 PM   #1354
sounds more the the ball cups are the classic too tight.
need to pop them off a few time s to streach the plastic, or take it out for a few runs, it will lossen up then
ed
Edwin Pibal is offline   Reply With Quote
Old 01-05-2011, 09:19 PM   #1355
me too, mine was all there and no mis tapped holes
ed
Old 01-05-2011, 10:05 PM   #1356
STLNLST's Avatar
That's good to hear as many of us have found some of the same issues with our B4.1's I know the car will be dialed. Just hope I'm not going to be in the same boat as many others as I have read
Old 01-05-2011, 10:30 PM   #1357
mine went together with almost no issues. the ball cups were a little tight. there a cup that if you pinch them with a plires will loosen up. mine didnt as much as i wanted. so i took a old ball stud made a small groove in it. and put it in the dremel at real low rpm. worked great.
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 01-05-2011, 10:53 PM   #1358
tqcookie's Avatar
Default TC6 Ball Cups
Ok, I am going to atempt to help any one who is having troubles with your
TC6 ball cups.
I was taught a long time ago when I got into Helis is there is a right way to install ball cups of this type. There is one side that is different from the other. The side with the numbers on them is molded differently than the other side. The side with the numbers has a larger opening and needs to be placed so the numbers face the ball you are snappiong them on to.
In these pictures you can see the difference in the two sides.
Another thing I learned when I got into helis is a neat way to perfectly size a tight ball cup. Squeezing a ball cup works in a pinch but alot of times isn't a permanent fix. What I am going to show you is not only easy but will make the cups fit perfectly.
1st take a spare ball of the proper size. Not all balls are the same. LOL Take a side cutter grab and squeeze the ball stud two different times 90* apart.
Squezze pretty hard as you ar trying to cut into the ballstud. You should now have 4 cuts 90* apart.
Once you have done this, click the ballstud into your favorite drill.
Pop a ball cup onto the ballstud and spin the drill for a few seconds.
Different drills spin at different speeds so it will take a couple of times to figure how much you will need. Also some cups will be tighter than others. So take your time. After you spin it for a few seconds check it on the car. If it is still tight do it again until it is perfect. I usually get all my tierods setup first then size them as needed. It also makes it easier to hold. Once you get a feel for how long to spin the drill it will go really fast.
I hope this will help those of you having trouble with the fit of your ball cups. Also those of you who think yours are pretty good, give it a shot. I think every one will soon see that AE didn't make a mistake with their molds. They made very good cups that with a little TLC fit absolutely perfect.
tqcookie is offline   Reply With Quote
Old 01-05-2011, 11:34 PM   #1359
pcar951's Avatar
Wow, good post tqcookie! I'll be giving this a shot for sure.
pcar951 is offline   Reply With Quote
Old 01-06-2011, 02:24 AM   #1360
Trader Rating: 54 (100%+)
Learn something everyday on this site.
Jamison R is offline   Reply With Quote
Old 01-06-2011, 04:24 AM   #1361
TQCooky u the man!!!!! Thanks.
Handbrake is offline   Reply With Quote
Old 01-06-2011, 04:27 AM   #1362
mine was issue free, too / first batch
but one thing to notice:
what shells are u us guys useing on your tc´s.
in europe we are mostly useing the
Protoform Mazda Speed6 or LTC-R
HB Mazda MPS
and for this shells, the front Body Stand is way to short
(have to put about 4mm unter it)
I love this car
greetings
thilo-alexander is offline   Reply With Quote
Old 01-06-2011, 05:00 AM   #1363
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Default Foam setup
Ok after many sets of tires and quite a few different tries.. I have a base setup.. very drivable has great feel and is close to how the tc5 was feelig though this car is entirely a different animal then the 5.
From here I start working tire combos.. this is really good with Jaco Douple pink/orange double pink.. works well with crc magenta magenta also heavy ca front edge.. or double pink, double pink heavy ca front edge..
Tires start 56mm.. RD ht 4.3
Also note we have spec/r gear diffs around the car with 1000 wt in them.
Track high bite carpet
front
shock oil 50- wt, piston #3 tower #4, arm B
spring purple.
Anti dive front mt 0B- 1.5mm spacer... rear mt 1B 1.5mm
Arm mounted to rear bifg shim in front small in rear
Camber link #4
Steering A 1mm bump steer spacer on arm
Servo saver #7B
Front diff mounted high
droop 5
Rear
Shock oil 30- wt, piston #3 tower 5, arm b
Spring blue
pro Squat front mount 1B 1mm spacer rear mt 2B 2, & 1mm spacer
.5deg rear hub
ball on hub 1mm spacer inner hole(A)
Camber link "5
Arm mounted to rear, large spacer in front
Diff mounted high
Droop 4
Just a start I am sure I will refine more.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-06-2011, 11:25 AM   #1364
JRXS_chris's Avatar
Quality post above for the ball cup treatment! Thanks!
I've just got a Spec R diff for the Yoke, I remember someone saying what needed trimming on it but cant find the post. Anyone remember?
JRXS_chris is offline   Reply With Quote
Old 01-06-2011, 02:35 PM   #1365
azz187's Avatar
Default E-clips
Maybe it's just me, however i'm having a hard time trying to remove the e-clips on the spur gear shaft, so much for easy spur gear access!
My e-clips just don't want to come off.
Has anyone else found this? Any tips?
azz187 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
