Like Tree1Likes
Old 01-04-2011, 01:03 PM   #1306
C.Andersson's Avatar
Default camber links
Originally Posted by pcar951 View Post
Short camber links in the rear are a must, IMO. Really locks in the rear of the car (on carpet at least).
Imo, there is no need to use shorter links at all. I've been testing camber links from short to long back and forth. Everytime I tried to go back from Long to short car was harder to handle and laptime constantly weaker.
After DHI Cup ill post my current setup to AE Site. My car has been real good recently on carpet. I got plenty of steering and grip without loosing cornerspeed.
hopefully I can TQ for Team AE again. And ofcourse win with better luck
Team Associated - Reedy - LRP - Sanwa - ProtoForm - Capricorn Rc
C.Andersson is offline   Reply With Quote
Old 01-04-2011, 02:00 PM   #1307
jhock's Avatar
The reason that 3rd mounting hole is there is if you use different spurs that dont have openings to get the screw behind it. I doesnt help with gear ratios
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 01-04-2011, 02:04 PM   #1308
Originally Posted by Buckaroo View Post
Thanks everyone. Makes 6.44 the lowest possible FDR with the stock gear in 48P. Not very Sportsman/stock friendly for the high 3s to the 5s. Hopefully AE will be releasing the purpose cut TC6 spurs soon. Until then, I'm off to order some Xenon gears.
Anyone have any other ideas?
28T/87T => 6.21 fdr use some dremel and you can put 29T
http://abram.eu.org/gear_tc6.php
Anyway, I don't have another spurs so I made some bigger holes.
Also use screw M3 with 2.5hex and ball-hex screw driver, it really helps
Regards!
m
Michal Abramowicz
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-04-2011, 02:39 PM   #1309
Buckaroo's Avatar
It would help if the standard AE Kimbrough or aftermarket Robinson spurs work. Hopefully my kit will be here shortly (damn holiday shipping delays). I'll try it once arrives. My skills aren't up to snuf yet for super stock boosted racing.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-04-2011, 02:39 PM   #1310
racing_jason's Avatar
Does anyone know when the TC6 will be instock for hobby shops? I really want one but it really sucks being told mid jan then moved to early jan then moved to mid Feb
Anyone got a real idea of when they will be in?
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 01-04-2011, 06:02 PM   #1311
TJames987's Avatar
Trader Rating: 10 (92%+)
Default qtn for the pros
I just attached all of the camber links to the chassis and everything is bound up so tight it can hardly move.
For the pros out there how do you free this thing up?
TJames987 is online now   Reply With Quote
Old 01-04-2011, 06:56 PM   #1312
rc pete's Avatar
After you pop the eyelets on the ball ends, you can squeeze them side to side with pliers. Start with squeezing them square on, and then you can also rotate them a little and squeeze side-to-side again all around.
Also, if you're not running the stock #7 camber link positions or the long steering link position, you'll need either some shorter camber rods (1.25" or 1.3" like on the TC5) or you need to trim the stock camber rods by 3 or 4mm on each side.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-04-2011, 07:33 PM   #1313
Timbulb's Avatar
I squeezed and squeezed and rotated and squeezed some more from every direction. I eventually just took them all off and put on some RPM ball ends.
Timbulb is offline   Reply With Quote
Old 01-04-2011, 07:36 PM   #1314
jag88's Avatar
Popping them on and off will help free them up but if that's not enough then chuck them up in a dremel and polish them with 1000 grit paper ..... butter.
jag88 is offline   Reply With Quote
Old 01-04-2011, 08:38 PM   #1315
Default Finally
I have finally finished my TC6. Nothing left to do but get rid of the 200mm sensor wire and get a 50mm from TQ. Then race!
Team Associated TC6 Thread-img_0103.jpg   Team Associated TC6 Thread-img_0111.jpg   Team Associated TC6 Thread-img_0105.jpg   Team Associated TC6 Thread-img_0117.jpg
Handbrake is offline   Reply With Quote
Old 01-04-2011, 09:05 PM   #1316
STLNLST's Avatar
Trader Rating: 21 (100%+)
Tekin also sells senor wire's
STLNLST is offline   Reply With Quote
Old 01-04-2011, 09:14 PM   #1317
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Those motor plugs are WAY too close! They can so easilly short out and your motor/speedie wont enjoy that Rest looks good though
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-04-2011, 09:56 PM   #1318
STLNLST's Avatar
Gonna place my order tomorrow so the car is ready for me once asphalt season starts.
Old 01-04-2011, 10:16 PM   #1319
Thumbs up Speedie
Thanks for the PM Ant3. I will put a small amount of heatshrink on the centre post,just at the very top where it is at its widest. I know that they disapate the heat so i won't do the whole thing, just the first 4mm. They just unplug, so it will be easy to get at.
Old 01-04-2011, 10:33 PM   #1320
ed517's Avatar
you better hurry Clint, falln behind the curve....
ed517 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
