Old 12-28-2010, 06:17 AM   #1216
Timbulb's Avatar
My batteries don't seem to fit well in my TC6. I've tried a few different brands of different sizes and I've tried every configuration of the braces, but they still slide forwards and backwards and side to side. Any tips on how to keep my batteries from sliding around even when taped in?
Timbulb is offline   Reply With Quote
Old 12-28-2010, 07:02 AM   #1217
Originally Posted by M.Abramowicz View Post
Hi!
Probably it was described somewhere but what spacer is need for same
effect.
In some setups is for example:
- 2mm spacer with sliver outer ball on hub...
Which spacer I should put for same effect if I use black ball ?
Regards!
m
edit:
probably 0.5-0.7mm silver is higher then black one ...
It is very close to 1mm. That is what I use.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 12-28-2010, 07:05 AM   #1218
Using the Reedy packs, I used dbl. sided tape to attach a piece of lexan to the front of the pack and that stoped all movement. That makes it a snug fit.
Old 12-28-2010, 09:06 AM   #1219
i1justin's Avatar
Trader Rating: 20 (100%+)
come on bulkheads, be available for sale soon please!
Soon all that mm under the ballstud means less thread in the plastic which is why the silver was used so you get extra height without changing the amount of thread into the hub making it a bit tougher, but good to know 1mm will work in a pinch with no silver studs available....
Also as a note dont use the offroad .030" silver ball studs, they do not have same thread as the metric silver/black and they will back out on you
Justin Wilde
AE - Reedy - JConcepts - Airtronics
Irony- Racing Nitro requires more Batteries than Racing Electric.
www.NCTracing.com
i1justin is offline   Reply With Quote
Old 12-28-2010, 12:32 PM   #1220
damage's Avatar
Default Losi LCD style drive shafts
I'm in the process of testing / tuning my TC6. Great car so far, but I have a question regarding the amount of chatter coming from the front end when turning.
I'm not running the set screws in the front drive shafts to free them up as much as possible. However, I still see and feel a lot of chatter from the shafts when turning still.
How come Associated isn't making a double jointed style drive shaft for this car. Doesn't seem it would be too tough to get one to market and I'm sure a lot of racers would scoop them up.
http://tinyurl.com/Wiocr
Tamiya Hornet, Airtronics XL2P, Novak 4, 1200 SC Stage III batteries,
Navcom 10 peak, 12 volt lead acid power source
damage is offline   Reply With Quote
Old 12-28-2010, 01:13 PM   #1221
touringdriver's Avatar
Trader Rating: 15 (100%+)
the double jointed front axles made a world and all difference in my 009 xray. very smoooooth!
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 12-28-2010, 01:24 PM   #1222
Big Features's Avatar
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 12-28-2010, 02:17 PM   #1223
jag88's Avatar
I saw one of the team drivers running Hot Bodies DCJ's with a spool. I know you would have to swap out the bearings to make it fit. Not sure if any extra shimming is needed.
jag88 is offline   Reply With Quote
Old 12-28-2010, 05:18 PM   #1224
mugenize1's Avatar
Anyone with a TC5 and a TC6 can tell me if the turnbuckle are the same size
I know that the TC5 is.
1 1/4 front camber
1 3/8 rear camber
1 5/8 steering
is this the same with the TC6 any info would help.
Thanks,Guys
mugenize1 is offline   Reply With Quote
Old 12-28-2010, 05:49 PM   #1225
Default Battery straps
Hi Timbulb, i used two velcro straps with the plastic loop on one of them. I sewed a loop at each end to slide tightly over the carbon fiber stays. The strap with the plastic loop on the end finishes about a third the way along the battery, then from the other end the velcro that is longer is threaded through the plastic loop and pulled back on its self (not too tightly because of tweak). The velcro seems to take up the slop between the battery and the stayin my case with no movement.
Hope this makes sense, and helps.
Anthony.
Handbrake is offline   Reply With Quote
Old 12-28-2010, 06:03 PM   #1226
mugenize1's Avatar
Anthony.
Can you post a pic to see what it should look like
Old 12-28-2010, 08:15 PM   #1227
Timbulb's Avatar
I shoe-gooed a piece of high density foam underneath the belt between the motor mount and the battery, and it holds holds really well now.
Old 12-28-2010, 08:43 PM   #1228
jhock's Avatar
Top racing makes a nice velcro piece, thats what i use
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 12-28-2010, 09:04 PM   #1229
hnasdad's Avatar
Just wondering, how come you dont just use velcro on the battery and chassis to hold the battery on? Too heavy? dirty? not enough to hold in a crash? A couple 4" pieces of velcro would certianly give you plenty of adjustment?
If you wreck in the same spot twice, your going too fast.
Tell a man his pinion he races today, teach a man about final drive ratio and he will stop making posts about them on forum's
Sketchy Racing (SC10,B44,10L5 Oval,TC6)
hnasdad is offline   Reply With Quote
Old 12-28-2010, 09:58 PM   #1230
Timbulb's Avatar
I use tape, but all my batteries were smaller than the space between the braces, by about a 1/4 inch. But like I said, I have the problem licked with a little shoe-goo and foam. Now tape works just fine.
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
