Like Tree1Likes
Old 12-27-2010, 08:46 AM   #1201
Originally Posted by asfastasu View Post
I too have an axle that will not rotate properly when the set screw is tightened. Otherwise kit does look nice, and it`s affordable.lol
The other way is to leave the set screw out and superglue the retaining ring on.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 12-27-2010, 09:00 AM   #1202
Buckaroo's Avatar
....or parts that work right the first time.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-27-2010, 09:54 AM   #1203
blackdog's Avatar
Originally Posted by Warren Weaver View Post
Just dremel the inner part of the shaft and the pin opening it will take care of it
Thanks for the input
blackdog is offline   Reply With Quote
Old 12-27-2010, 10:14 AM   #1204
jag88's Avatar
Hey Walt , use your years of seniority to get them to fix the shocks ! ... lol
jag88 is offline   Reply With Quote
Old 12-27-2010, 11:25 AM   #1205
I haven't had any problems with them. Whats your issue?
Old 12-27-2010, 11:59 AM   #1206
azz187's Avatar
Originally Posted by Q_man View Post
Hi All,
Just started building mine and look to be missing some of the o-rings. I have a set of red o-rings from by B4 just wondering if anyone knows what size the shock collar o-ring is?
Wayne
Edit: Sorry no need to worry I went through all the bags and found them in another bag.
I did the same thing!
I thought I was missing o-rings and then found them in another bag, haha.
By the way, they are the same as the b4 o-rings if you ever need to replace them....
azz187 is offline   Reply With Quote
Old 12-27-2010, 02:34 PM   #1207
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Default Assembly and CVA Axles
Just a little advice following up some recent posts. When I assembled my TC6 I skipped the shocks and the diff right off. You find out later that some of the parts needed in the assembly are in those and other bags.
As far as the CVA's, I had one that stuck when the set screw was in. I took another back apart and swapped around parts. Then they both were smooth and unbound. I am not sure if it was the rebuilding from scratch or if the parts worked better swapped. Either way in the end they were all good.
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 12-27-2010, 02:46 PM   #1208
jag88's Avatar
Originally Posted by olhipster1 View Post
Hey.....Merry Xmas everyone.
any special tips on building the shocks...
i've built my TC6 shocks a few times and i'm still getting a bit of stiction on two of the four.
Any help would be appreciated.
stiction. When you get a chance talk to JR he also had some issues.
Old 12-27-2010, 03:34 PM   #1209
Big Features's Avatar
Stiction indeed, even tried using "green slime". A teflon guide and endseal like those on Tamiya would be a great option.
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 12-27-2010, 05:52 PM   #1210
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default stiction galore
i finally got the stiction out had to rebuild it a number of times.
and tried green slime, silicon...etc.
think the plastic insert was binding just a bit.
ending up reaming just a slight amount of plastic from it, and it seems to take care of the problem.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-27-2010, 06:30 PM   #1211
jag88's Avatar
My opinion of the problem is that either the spacer or the rod guide is to thick and when you tighten the cap it squeezes the o-ring and in turn pinches the shock rod. If you back the cap off a little the problem goes away. Unfortunatley you can't run that way. I tried using a 3mm and .75mm shim in place of the spacer and it made for a smoother shock. I don't know exactly what combination of shims is perfect.
I ended up using Tamiya shocks. It's a shame really ....
Old 12-27-2010, 06:33 PM   #1212
If that's the case, then why not just sand down the spacer slightly on a piece of sandpaper??
Serzoni is offline   Reply With Quote
Old 12-27-2010, 06:40 PM   #1213
jag88's Avatar
I thought of that but thought that using shims was faster and more accurate but I didn't have enough for all four shocks.
Old 12-28-2010, 01:30 AM   #1214
That works in my case. And now they are very smooth and easy to bild.
-Markus
Team Associated Tc6 | Sanwa M11x | LRP Sxx Tc Spec | Sävox | GM
rrike is offline   Reply With Quote
Old 12-28-2010, 01:32 AM   #1215
Hi!
Probably it was described somewhere but what spacer is need for same
effect.
In some setups is for example:
- 2mm spacer with sliver outer ball on hub...
Which spacer I should put for same effect if I use black ball ?
Regards!
m
edit:
probably 0.5-0.7mm silver is higher then black one ...
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
