Old 12-19-2010, 10:27 AM   #1096
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jackdani View Post
first step done!
Nice.....did you seal the edges of the chassis?
STLNLST is offline   Reply With Quote
Old 12-19-2010, 12:04 PM   #1097
wtcc's Avatar
Hello guys,
I had my first race today (LRP-HPI-Challenge, 17,5t-class) with my new TC6. Oh, boy this car is so much easier to handle through qualifyings and finals! This time I could really concentrate on my driving (instead of taming the car = TC5). Unfortunately my setup (and/or my driving) wasn't good enough for a win, but with a fifth overall position, my best yet, I am very satisfied. And I am looking forward to get faster
The A-Finalists then showed up at my place to see the car and they all where surprised how well it behaves on track.
I think with this car AE can reestablish their reputation in TC in Germany.
wtcc is offline   Reply With Quote
Old 12-19-2010, 12:05 PM   #1098
Originally Posted by M.Abramowicz View Post
New gear chart for tc6
Tested on 48 module, for 64 should be fine it is only mathematics
http://abram.eu.org/gear_tc6.php
29x87 on 48p will not fit it need 0.2mm more
Thanks man. This is getting printed and put in my pit box!
jmann591 is offline   Reply With Quote
Old 12-19-2010, 12:56 PM   #1099
Originally Posted by wtcc View Post
Hello guys,
I had my first race today (LRP-HPI-Challenge, 17,5t-class) with my new TC6. ......
Post you setup Maybe some coments and what you change for better drive.
Wish you good luck at next race!
m.
Michal Abramowicz
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-19-2010, 12:58 PM   #1100
No problem!
Also I don't know if 114T/64p will fit ... Must calculate diameter,
but I race on 48p so ) anyone ? have so big spur?
Michal Abramowicz
Old 12-19-2010, 01:11 PM   #1101
rccuba's Avatar
hi all, anyone know if you can put a 90T/48p.....
is that in the above table is not the 90T/48p
thank you very much everyone, this weekend I could not put the car on the track, it has been raining every day, jejejej
Team Associated TC5 & TC6, ROBITRONIC, Mamba Max PRO
www.rccuba.es
www.instalaciones-jcb2.com
rccuba is offline   Reply With Quote
Old 12-19-2010, 01:24 PM   #1102
I don't have 90T/48p, but 87T is soo big maybe will fit maybe not,
if you put it and it will be working OK, just say, and I move table
Regards!
Michal Abramowicz
Old 12-19-2010, 01:34 PM   #1103
rccuba's Avatar
ok,.... as soon as I get of the pondre 90T/48p and see if it is ....
I ask because with the electric motor that I have now, the Mamba 6900KV ... I can not put a smaller pinion than 23 teeth, as the engine hits the sub-frame, would have to look for a motor that has the bevel around the edges to put more towards the crown, otherwise I'll find a crown bigger, jejeje
Forgive my English but it is the google translator ....
later I'll post a picture of where the engine hits, now I have him as a pinion 23 with that of 87T/48p ....
www.rccuba.es
Old 12-19-2010, 01:39 PM   #1104
wtcc's Avatar
m.
Here you go:
http://img375.imageshack.us/f/dsc00350s.jpg/
Originally I wanted to copy Kevin Herberts Setup, but TT was too slow, so I had no 6° Caster Blocks. The setup without them and without his custom made pistons was 3tenth slower than this setup which is based on the standard setup. I changed some things to gain more grip and to increase steering (for example rear camber link and front droop).
What I still need is a little more grip in the rear. If the track is not "high grip" the rear is loose.
Old 12-19-2010, 04:42 PM   #1105
jackdani's Avatar
yep!
i ve done that..BUT i used nail enamel (no color), which actually turned out way better than glue!
hope will last for a while, anyway putting it again would be very easy!
jackdani is offline   Reply With Quote
Old 12-19-2010, 06:31 PM   #1106
I am running Keven H halloween setup on my car and it has been great. The only thing I have noticed recently (track change) is on 2 really sharp corners it I go in to fast and try to shove it in there, the car seems to fall on the front a little. Meaning it tends to lift the opposite rear tire slightly and it diffs out when trying to get back on power.
My buddy was having the same problem and has gone to blue springs up front. The lifting has gone away but he said he has a slight push now. We also tried more and less droop without help.
My thought was to maybe add an o-ring on the outside of the front shock to limit up travel, so the car won't fall on it's nose as much. Do you think this will work or is there something else I should be looking at instead.
DJG24 is offline   Reply With Quote
Old 12-19-2010, 07:14 PM   #1107
ed517's Avatar
suffered the same issue with my 17.5 car on a tight carpet track. this is what i changed
Shocks
45wt oil
#3 pistons
gold springs
fwrd arm mount 3b
Rr arm mount 1b
Yes, this is 8 deg of caster!!
i also removed the rear sway bar.
this improved my fast lap by .3 and top 20avg by .2 . Everyones driving style is different so....
ed517 is offline   Reply With Quote
Old 12-19-2010, 07:15 PM   #1108
try taking the rear sway bar off compleatly
ed
Edwin Pibal is offline   Reply With Quote
Old 12-19-2010, 07:45 PM   #1109
mugenize1's Avatar
Default Mamba Max
I have two Mamba Motors. What would work best the 5700Kv or the 6900Kv I also have two ESC the Pro and one with green fins.
mugenize1 is offline   Reply With Quote
Old 12-19-2010, 09:34 PM   #1110
ed
Agree 100%
Josh Hohnstein is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
