Like Tree1Likes
Old 12-16-2010, 03:37 PM   #1066
Trader Rating: 54 (100%+)
He bought both from debs
Jamison R is offline   Reply With Quote
Old 12-16-2010, 04:39 PM   #1067
azz187's Avatar
Originally Posted by Chris Furman View Post
What is your flat surface?
Glass kitchen top and it's dead flat, I even double checked on different flat surfaces and the chassis is still rocking from side to side...
azz187 is offline   Reply With Quote
Old 12-16-2010, 05:15 PM   #1068
A Ilievski's Avatar
Trader Rating: 39 (100%+)
I have the exact same problem. I just finished building the car and through building it i noticed the bottom deck is tweak. Wobble side to side when on a flat surface. Ive over looked everything so I don't know what the issue is. Out of 6 other high end cars Ive built/driven, I've never had one like this out of the box
Any ideas?
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is online now   Reply With Quote
Old 12-16-2010, 05:29 PM   #1069
Trader Rating: 114 (100%+)
Any ideas?
Take the tires off... put the chassis on a flat surface.. loosen ALL the screws on the top deck and shock tower mounts. While holding the chassis down flat on the surface from the top. Start tightening all the screws down.. in an X-pattern from front to back to front, etc... That should get rid of your tweak.
Chris Furman is offline   Reply With Quote
Old 12-16-2010, 06:02 PM   #1070
DaveW's Avatar
I was just there Monday... "Nope we dont have one in stock."
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-16-2010, 06:57 PM   #1071
A Ilievski's Avatar
Alex Ilievski
Old 12-16-2010, 09:05 PM   #1072
sesimon's Avatar
Any ideas?
Did you check to see if all the screws are counter sunk completely? That could cause the wobble side to side. I know I actually need to counter sink my screws a little more than what the factory did.
2008 ROAR Nationals 13.5 Rubber 9th Place
2007 HOA 1/8 Runner-up
2006 ROAR Region 8 1/12 Stock Champion
2005 ROAR Region 8 1/8 on-road TQ/Champ
www.fastlanehobby.com
www.heartofamericaseries.com
sesimon is offline   Reply With Quote
Old 12-16-2010, 09:07 PM   #1073
Mowell's Avatar
Originally Posted by Team T2C View Post
These are from november, so i hope it is good. I havent heard any bad things about the other kits, so maybe it happened during the second run of kits.??? Maybe
My Kit was perfect from the stock you got in.
TC6, Ten SCTE, Novak, Fantom, Savox, Spektrum
Mowell is offline   Reply With Quote
Old 12-17-2010, 02:22 AM   #1074
1 of the kits had unthreaded parts. He bought both and they are getting parts to fix second kit. Which John already owns.
Old 12-17-2010, 04:01 AM   #1075
daleburr's Avatar
Hey guys,
Just unpacked my TC6 and after reading this thread I’m paranoid about missing parts and unthreaded bulkheads…
After inspecting the bulkheads which all had threads, I placed the main chassis on a flat surface and I found the chassis to be twisted and rocking from side to side.
Has anyone else had this and did you contact AE for a replacement??
I think some people are misunderstanding; if it's doing this with just the chassis (no other parts attached) then its nothing to do with how the car was built, the chassis must be faulty.
I'll be sure to check mine carefully when it arrives...
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-17-2010, 04:47 AM   #1076
rccuba's Avatar
hi all, I bought my TC6 on Tower H. and when he came to my home in Spain, the first thing I did was check everything right and get the mount ..... not a single failure in any part ..... in fact already have shot at least 18 batteries ...... a luxury to have this model ......
greetings from Spain to all
Juan Carlos
Team Associated TC5 & TC6, ROBITRONIC, Mamba Max PRO
www.rccuba.es
www.instalaciones-jcb2.com
rccuba is offline   Reply With Quote
Old 12-17-2010, 05:25 AM   #1077
New gear chart for tc6
Tested on 48 module, for 64 should be fine it is only mathematics
http://abram.eu.org/gear_tc6.php
29x87 on 48p will not fit it need 0.2mm more
Michal Abramowicz
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-17-2010, 06:41 AM   #1078
azz187's Avatar
The first thing I checked was the bulk heads and the chassis on a flat surface with no parts attached.
This is the first time I've built a TC kit and found a tweaked chassis, I'm a bit disappointed.
Can anyone tell me if associated is likely to send me a replacement for this faulty main chassis? I've emailed them with my receipt and still waiting on a reply.
Old 12-17-2010, 06:45 AM   #1079
AE has some of the best customer servive out there.
If there is a problem with a new kit or part they will take care of you.
Josh Hohnstein is offline   Reply With Quote
Old 12-17-2010, 10:57 AM   #1080
timmay langdell's Avatar
check that the motor mount brace (31313) lines up with the chassis hole, i had to sand about 1mm to get it to line up.
that could be the cause of your tweek.
timmay langdell is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
