Like Tree1Likes
Old 12-15-2010, 02:41 PM   #1051
mines finished
i didnt have any problems with my build all parts were good, nothing missing.
if anything, i was looking for something wrong, but gladly didnt find anything
ed
Edwin Pibal is offline   Reply With Quote
Old 12-15-2010, 03:21 PM   #1052
Buckaroo's Avatar
Originally Posted by spongerX View Post
Has anyone bent the TC6 arm mount bolts or deformed the plastic arm mounts using the 12R5 spacers? With the mounts being spaced so far off the bulkheads now it looks like these parts would get damaged with a hit on a wheel since there's nothing supporting the lower part of the arm mount which is where the hinge pin is installed so the arm mount assembly is acting like a lever if the car gets T-boned on a wheel. An aluminum arm mount spacer that's the same size and shape as the stock plastic spacers to better support the plastic arm mount would be a nice option part.
You got that 100% correct.
I don't have a TC6 yet, but they're the same design as the TC5 (which I have), and using aluminum spacers instead of the toe shims, I've bent screws, broken the mount pieces, broken the aluminum threaded inserts, and sheared the screws or a variety of that on all 4 corners. Some were board hits, some were hits with other cars.
Since I switched back to the plastic spacers and installed longer Traxxas steel screws (3x15mm), I haven't had a single issue.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-15-2010, 04:08 PM   #1053
Trader Rating: 114 (100%+)
Never had an issue with bent screws. Even with my old TC5.
Although in theory longer screws should resolve the issues you guys are talking about. Stay away from stainless or aluminum in these positions. Tonys screw kits are a real nice strong metal if you don't want AE screws.
I have had bent rear hinge pins in my Tamiyas.
Chris Furman is offline   Reply With Quote
Old 12-15-2010, 04:20 PM   #1054
One quick slightly off topic question:
When did Associated go to metric screws? All my other AE stuff (RC10, TC4, TC3) is standard thread. I noticed because all of the talk of using M3 taps in the bulkheads.
duanew is offline   Reply With Quote
Old 12-15-2010, 04:48 PM   #1055
trerc's Avatar
Trader Rating: 89 (100%+)
This changed with the TC5
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-16-2010, 07:01 AM   #1056
#31227 CVA coupler
broken thread
probably I can do new M3 at another side
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-16-2010, 07:55 AM   #1057
I didn't even put the setscrews in my CVAs. I just put a tiny drop of CA on the retainer rings to keep them from popping off in an accident. I even do this on my offroad cars and it works great. Helps free up the CVAs slightly, too.
Serzoni is offline   Reply With Quote
Old 12-16-2010, 02:26 PM   #1058
jhock's Avatar
Tell you what about this car. Bought one to try out, lets say I both another one.
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 12-16-2010, 02:27 PM   #1059
azz187's Avatar
Hey guys,
Just unpacked my TC6 and after reading this thread I’m paranoid about missing parts and unthreaded bulkheads…
After inspecting the bulkheads which all had threads, I placed the main chassis on a flat surface and I found the chassis to be twisted and rocking from side to side.
Has anyone else had this and did you contact AE for a replacement??
azz187 is offline   Reply With Quote
Old 12-16-2010, 02:46 PM   #1060
Originally Posted by azz187 View Post
Hey guys,
What is your flat surface?
Old 12-16-2010, 02:47 PM   #1061
Old 12-16-2010, 02:57 PM   #1062
Trader Rating: 54 (100%+)
prima donna
Jamison R is offline   Reply With Quote
Old 12-16-2010, 02:58 PM   #1063
jhock's Avatar
HEHE
SVR
SX3
Tekin
KO Propo
Old 12-16-2010, 03:06 PM   #1064
jhock's Avatar
Anyone have gear diffs for sale or know what store I can get some? Thanks
SVR
SX3
Tekin
KO Propo
Old 12-16-2010, 03:34 PM   #1065
DaveW's Avatar
WHAT?! You had to order it... i checked there wasnt one local.
not that i was looking to buy one or anything
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
