Like Tree1Likes
Old 04-06-2016, 09:46 PM   #10246
afro_lou's Avatar
Originally Posted by tommysnow7 View Post
Recently bought a tc6.1 for usgt, does anyone have a setup for this class? Thanks
Sorry, I don't have a full setup sheet for you, but mine's set up as such:
Arm mounts as low as possible (1 dot on the lowest hole, or no dot on the upper hole)
-1 camber all around
30wt oil in the shocks w/softest springs (12.5lb, I think?)
As much droop as you can get
5.5mm ride height
I'm pretty new to this, but had some good help from an experienced usgt driver to get this setup.
Good luck!
afro_lou is offline   Reply With Quote
Old 04-07-2016, 06:40 AM   #10247
Location: Beneath a rock down by the river. Don't have money for van
Originally Posted by phatboislim View Post
get some extra offset arm mounts, one pack of front arms and a couple packs of front caster blocks...that should be pretty solid to hold u on any breakages. but in general if the chassis isnt twisted and everything looks ok and feels solid then it's probably ok
I only broke a rear hub so far so I would suggest them too, all TC6 parts except the diff.
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 04-07-2016, 07:37 AM   #10248
Trader Rating: 18 (100%+)
i've had my TC used and i've never broken a rear hub. i just replaced the offsets in them so there wouldnt be any play in the outer hinge pin
but i know everyone is different
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 04-08-2016, 03:00 AM   #10249
It was a TC6 hub and broke horizontally (along the axle) in a sideways crash, since then I never had another crash worth mentioning. Are you going to use TC7 arms? Would you kindly measure them?
( ͡ ͜ʖ ͡)
Old 04-08-2016, 04:37 AM   #10250
i'll measure it for you...you have to have a shit ton of shims too btw. but it is smaller than the TC6 arms by alot..i'd say probably about 10mm. i loosely followed Keven Herbert's setup. I'm also using the reflex shock towers...i have to reorder them unfortunately though.
http://site.petitrc.com/reglages/ass...ice2015121113/
Old 04-08-2016, 12:09 PM   #10251
Lone Drifter's Avatar
Originally Posted by cosmicpilot View Post
some times my car pulls to the left on my tc6.1
can any one help please
I have also had where one of the CVD joints would stick just even a little and the car would spin our pull in one direction
A bent shock shaft sometimes will do that too.
USVTA , USGT and Wheeler
TC7, TC6, T3 11 & 12, and TLR 22-4
Lone Drifter is offline   Reply With Quote
Old 04-09-2016, 07:27 AM   #10252
*snip*]
Thanks, really appreciate it.
If not asking too much would just need hinge pin to hinge pin length and shock hole to inner hinge pin length. I'm eager to find what are the big changes in that aspect.
( ͡ ͜ʖ ͡)
Last edited by 30Tooth; 04-09-2016 at 07:30 AM. Reason: removed pic to not clutter the thread
Old 04-26-2016, 08:11 PM   #10253
i broke many of the front c hubs on my tc6
nova69 is offline   Reply With Quote
Old 06-25-2016, 03:56 AM   #10254
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Quick question, will the gear diff fit in my 6.1?
I bought this as my first TC car/ VTA car and it works great. liked it so much I bought the TC 7 lol.
Great car to learn on and they are cheap!
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 06-25-2016, 04:32 AM   #10255
gigaplex's Avatar
The 6.1 comes with a gear diff. Which gear diff are you asking about?
gigaplex is offline   Reply With Quote
Old 06-25-2016, 09:55 AM   #10256
JEFFs SC10's Avatar
Oh I thought it had a ball diff, if that's the case then I just need to put some thicker diff fluid. Feels very loose. I run on high grip crc carpet.
XRAY 2017 T4
Xray X12-17' GT12
Old 06-25-2016, 03:25 PM   #10257
gigaplex's Avatar
The 6 came with a ball diff, the 6.1 switched to a gear diff. Post a picture and we'll be able to tell you what you've currently got.
Old 06-25-2016, 05:38 PM   #10258
adriang79's Avatar
Check your spool drive cups and drive blades on end of CVD. The plastic spool cups can be easily damaged and the drive blades snap. I use the steel spool cups from the TC6.2, no drive blades needed with this.
adriang79 is offline   Reply With Quote
Old 06-25-2016, 09:38 PM   #10259
JEFFs SC10's Avatar
yup I got a gear diff. I'm a dumba.. I put in thicker lube as it felt like there was none in there. I run on high grip crc carpet so this should help.
Can I run the steel outdrives in the rear so I dont have to run those blades?
XRAY 2017 T4
Xray X12-17' GT12
Old 07-01-2016, 03:34 PM   #10260
JEFFs SC10's Avatar
Just an update, the change in the diff helped I TQ'd and won in VTA !
This old chassis gets the job done!
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28963 07-28-2017 05:20 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
