Like Tree1Likes
Old 12-22-2014, 05:50 PM   #10201
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
take a screen shot of your setup and attach that instead
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 12-22-2014, 06:33 PM   #10202
YoDog's Avatar
Originally Posted by Goof View Post
Hi guys I got into carpet to keep my racing going In tell off road . I'm racing 12r5.2 and tc6 in my tc the tc servo keep coming on done like Iv read here now does this floating servo parts help or only floats the servo off the chassis ?
Can you clarify what you mean by "the TC servo keep coming on done"?
The floating mount is for attaching the servo to the center line of the chassis and removing it from being a structural member of the chassis plate.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-23-2014, 08:23 AM   #10203
Goof's Avatar
Trader Rating: 38 (98%+)
Send a message via MSN to Goof
The nut that keeps the spring on I talk to a few guys it happens so I ca it because it came off twice thank for your reply
I oder all new parts incase they brakes but at least it hasn't came off yet. I got four good runs without it coming off so it Has been worth it.
Goof is offline   Reply With Quote
Old 12-23-2014, 09:36 AM   #10204
ViperZ's Avatar
My servo saver nut has stayed on after a day of racing. I loctied the crap out of it. Time will tell if it holds up or not. I have Yodog's Floating kit to be installed when and if it fails again.
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 12-23-2014, 10:22 AM   #10205
BulletMan's Avatar
Default martin's tc6
try this...
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 12-25-2014, 01:27 PM   #10206
BulletMan's Avatar
any thoughts? i need help
Old 12-25-2014, 01:43 PM   #10207
Originally Posted by BulletMan View Post
I could use a little help with my setup...
TC6.1W.... lowered shock towers and WC top plate
I am have a really hard time getting the rear of the car planted... it really wants to over rotate from mid comer to exit.
i attached my setup from our club race yesterday.
WHAT THE Hxxx? my PDF is too big to upload! i need help on the too please.
4mm droop over ride height is pretty big to begin with, try something like 1.5 in the front and 3 in the back.
Try lighter rear diff fluid as well.
Move the tops of your front shocks in to the 2nd inner hole and run the rears in the 4th inner hole.
Try to reduce the rear inner upper link spacer by 1mm or raise the outer by 1mm.
JMO
Rodney Racer is offline   Reply With Quote
Old 01-11-2015, 09:25 PM   #10208
Scottrik's Avatar
Trader Rating: 241 (100%+)
Need some coaching on venting my VCS3 shocks.
In the day on TC3 shocks if we couldn't find some Yokomo caps we used to drill the cap and thread in a 4-40 set screw to seal it up after the shock had been bled.
Now it sounds like a smaller hole is being drilled and is left open to the atmosphere as a true vent. Is this correct? I guess we're relying on the bladder to hold the oil in the shock body.
How big of a hole? Does it matter where in the cap?
Anybody got some pics?
Many thanks,
Scott
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-12-2015, 04:13 AM   #10209
ViperZ's Avatar
Many thanks,
Scott
Correct on the venting. I drilled mine and they do not leak through the hole. I used a 1mm drill bit.
Drilling out the tops of my shock caps to make them zero rebound
RSD Bladders
Old 01-12-2015, 06:42 AM   #10210
Scottrik's Avatar
Thanks very much Viper...that's pretty much what I was envisioning.
Thanks also for the pics! When I first read your post I was wondering if I have a 1mm drill bit. When I saw your pic I KNEW I did because I have that same finger drill and bits that I hadn't even thought of.
Off to go drill me some caps! Lucky me the shocks already have the RSD bladders in them.
Old 01-12-2015, 03:51 PM   #10211
mugler's Avatar
when you drill the caps (or not for that matter) is it necessary to use those small foam cylinders that go on top of bladder?
mugler is offline   Reply With Quote
Old 01-13-2015, 07:49 AM   #10212
YoDog's Avatar
The foam is not needed.
Old 01-13-2015, 04:54 PM   #10213
mugler's Avatar
Old 02-14-2015, 09:58 PM   #10214
IndyHobbies.com's Avatar
Is like to get another TC6 but they seem kind of scarce on eBay and here.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 03-03-2015, 10:50 AM   #10215
bluer322's Avatar
Does anyone know were to buy 750,000 diff oil
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Triple A
