Like Tree1Likes
Old 09-25-2014, 05:09 AM   #10171
Castradamus's Avatar
Trader Rating: 53 (100%+)
Originally Posted by Eearlyboid View Post
I'm also curious about the answer to this question. I just put all new ceramic (grease removed) bearings into my car, but everything still feels stiff. So, I too am wondering if there is a solution to the stiffness.
Generally you can get binding in your drive train from a number of source. You should check that as you build the car. I would start by removing the tires, drive hex, pins and shims. Then spin the drive train to see if it feels looser. That would give you a good starting point.
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 12-07-2014, 01:43 PM   #10172
ViperZ's Avatar
Anybody know the fix for the TC6.1 servo saver popping loose/off? I'm sure it's been covered however I could not find it in a search.
That's 2 weeks in a row now. The first week it popped loose after 3 rounds, the car was newly assembled. The second time, today. I had locktite'd the thread and cap, but no use. It popped off first round...
What's the solution? Is there a West/South conversion, kit?
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 12-07-2014, 10:01 PM   #10173
YoDog's Avatar
Trader Rating: 26 (100%+)
Are you talking about the spring tension nut? If so, thread locker should work but you have to let it setup for 24 hours or so. I'm not sure what you mean by "popped off" as it sounds like something should first be popped on before it can pop off. I used to make a 90* saver cam to go along with my floating servo mount but it's a bit expensive to make at this time so I stopped.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-08-2014, 03:42 AM   #10174
ViperZ's Avatar
Hi Rick, yes the spring tension nut spun off (popped ) I did use thread locker and let it set up over a week. Maybe I need to use lots more, or even Red.
I actually purchased your Floating servo mount, but don't know what else is required with the kit to convert he 6.1 over.
Old 12-08-2014, 02:24 PM   #10175
YoDog's Avatar
Does it seem like the nut is stripped or maybe just loose? once you have it set (pretty tight) you are not likely going to reset it. Tighten the nut and apply a little CA glue.
Now for the servo mount... You will need 1 short AE ball stud (the black one I believe) with 8mm length threads. This will replace the button head screw used on the Ackerman adjustment. You will need 1 AE long ball cup like the ones used on their off road kits. I use these from time to time so they are good to have on hand. With these 2 parts, you will be able to connect the servo to the steering directly. Everything else is either being used already or at least came with your kit like 1 of the factory servo mounts and spacers to get your servo into the right position. I can send some pics if that will help.
Old 12-08-2014, 07:21 PM   #10176
mtbboy's Avatar
I ran a servo saver and glued mine in addition to removing the spring.
mtbboy is offline   Reply With Quote
Old 12-11-2014, 01:40 PM   #10177
wtcc's Avatar
I cannot send my 6.1 into retirement
It now is the base for a (maybe strange) conversion. The idea is to have an ultraflat 4-wheel-drive chassis with a 235mm pan car body
Nearly two years ago I showed how to fit flat bodies (GT and/or Pan) on the TC6 chassis. I will use this idea and combine it with ridiculous wide foam tires to get this:
Still a lot to do. Body and servo mount (need one more) are ordered. Then I have to adapt to the body width with spacers under the suspension mounts and hexes. The front has 215mm already, the rear can be 227mm
I just hope the front is low enough to fit under the body...
In the end this thing shall break track records and be fun!
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 12-12-2014, 11:39 AM   #10178
Front tires too wide.
Use max 30mm from regular 1/10 nitro car
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-12-2014, 01:07 PM   #10179
wtcc's Avatar
Trust me I am not an engineer
Old 12-13-2014, 04:15 AM   #10180
ViperZ's Avatar
Yo, please do send some pictures, Thanks!
Okay, I have applied a load of Loctite, it has sat for a week now. I'll try it this weekend. The threads look fine, it's just coming loose.
The servo saver cleared the top tray?
That think looks plain wicked, regardless of how it works out
Old 12-18-2014, 07:55 AM   #10181
Need some info please...searched google and this forum and see it talked about but not how to do it. I have a 6.1 and as of yesterday my large belt falls off after a couple laps. I dont see how to tighten the belt? I am fairly new to RC so any help will be appreciated..Even a link on how to..thanks in advance
omaharich68 is offline   Reply With Quote
Old 12-18-2014, 08:17 AM   #10182
Trader Rating: 25 (96%+)
Here is an example illustration from Xray which uses the same design, simply remove the upper bulk head and rotate the bearing holder in the respective direction in order to tighten it... if you max out the adjustment and the belt is still loose, then it's time to replace the belt as it has stretched out too far:
billdelong is offline   Reply With Quote
Old 12-18-2014, 08:30 AM   #10183
thanks for the info...the bearing holder looks like it is 2 piece? do i rotate like a ratchet (like with a little force)..or simply rotate it and reinstall the bulk head? I took it apart yesterday and it just seems like it wants to lift out of the bearing holder and only fits in there one oblong way...lol sorry i told you i was a newb..
Old 12-18-2014, 08:34 AM   #10184
also i just saw a pic of the xray...and i see the different grooves the diff would fit in...on my 6.1 i dont have those grooves it is smooth..i do see teeth within a plastic part of the bearing holder..not sure if it rotates within itself or not??
Old 12-18-2014, 08:36 AM   #10185
yes, lift it out of the bulkhead, rotate it, then re-insert the bearing holder so that each notch is in the same slot on both sides of the bulk head. Keep increasing one slot at a time until you reach the desired tension. With the TC6... I think the grooves are inside the plastic bearing holder itself... same concept with XRay.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
