Like Tree1Likes
Old 04-25-2014, 02:04 AM   #10081
turtlehill's Avatar
Default Balance
Originally Posted by Nickerz View Post
I noticed when I accelerate my car pulls to one side. So much so that it will even sometimes spin out. My LHS shop looked at it but couldn't figure it out. It doesn't seem to be the steering servo as it doesn't do it when I gradually accelerate.
Recently, I was holding my car and I noticed the front, right CVA bone was wobbling when I increased the throttle. So I replaced it with a new spare I had. The car still seems to pull but not as much. Could this be the issue or am I imagining it got better? Any thoughts as to what will cause this and how to fix it ?
Ever tried balancing your tires? Excessive vibration affects handling and wears out your suspension components faster.
turtlehill is offline   Reply With Quote
Old 04-25-2014, 02:24 AM   #10082
You should first look at tweak, e.g if the chassis sits flat on a flat board.
Anything else could be useless if there is just tweak.
Then have a look at your diff
Cheers
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 04-25-2014, 03:40 AM   #10083
turtlehill's Avatar
Originally Posted by cam345 View Post
I have a tc 6.1wc that I race 17.5 touring on outdoor asphalt. Car is set up as per manual. Rear end has absolutely no traction. Any ideas? Thanks in advance.
Softer rear springs, shock position(less vertical), 4 hole pistons with heavier oil, rear diff - 1300CST oil, front diff - 2.5m Gravity oil.
Let off/brake earlier entering turns. Smoother throttle exiting turns.
Someone told me "slower is faster". Sounds crazy until you try driving that way.
If all else fails, get a TC6.2. It's a much better designed car. Easier to drive.
Old 04-25-2014, 10:49 AM   #10084
Holeshot114's Avatar
Tire balancing? Can you give a noob an example of how to do that?
Holeshot114 is offline   Reply With Quote
Old 04-25-2014, 11:02 AM   #10085
Trader Rating: 25 (96%+)
here's one I've been using for a while now and I've been very happy with it so far:
+ YouTube Video
billdelong is offline   Reply With Quote
Old 04-25-2014, 01:32 PM   #10086
turtlehill's Avatar
Default Tire balancing
There are different balancers on the market, some specifically for car tires. I use a Du-bro prop balancer since I also fly rc planes. There is also sticky back balancing tape in rolls available at AMain Hobbies among other online shops.
I can't post the URL's for the equipment but go to AMain Hobbies and look up tire balancing. They list the Losi and Du-Bro balancers along with the balancing tape.
The process is simple, once your tires are mounted and glued, you place the tire on the balancing jig and the heavy side will rotate to the bottom. You then cut a piece of the balancing tape and stick it on the inside of the rim at the highest point. Experience will tell you how a big a piece to start with.
Depending on the imbalance, the tire will now rotate to the new heaviest point. In some cases, you will need to make a bigger or smaller trial weight and replace the original weight. If it rotates not quite all the way down, you might have to move the balancing weight one way or the other to find the exact placement.
The real key in balancing tires is to make sure you have the tire exactly centered on the balancing spindle to begin with. When you reach the point where you can spin the tire and it never stops in the same position, you are very close.
Take note when you are holding your car and revving the motor. Do the tires look like they are wobbling and the turnbuckles appear blurry because they are vibrating so hard? This can translate to loss of traction because of poor contact due to the vibration.
If you race VTA, balancing is a must as the HPI tires and rims are so big and heavy it makes a huge difference in the handling.
Old 05-03-2014, 06:37 AM   #10087
Just bought a TC6.1 WC for TC 17.5 class. What would be a good setup to start out with. I have a TC6 that I run for VTA but I'm not sure if that setup would do well in a different class. The track that I mainly run at is 73 x 40 carpet medium traction. Also what is a good brand of rubber and wheels to run? I've heard of sweeps but never ran them.
Wil
Never give up!
Traxxas Slash 2wd, Spektrum DX4c, Associated B5m
Wil Holmes is offline   Reply With Quote
Old 05-03-2014, 07:08 AM   #10088
scooby61's Avatar
Wil
Your via setup should be a good starting point if it handles well on the same track then adjust from there for the skinnier tires and lighter weight. I've run sweeps, much mores, and sore for tires prefer the sorex 32 and 36 shore on pavement
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 05-03-2014, 07:16 AM   #10089
Thanks I'll start with my VTA setup then and go from there.
Never give up!
Old 05-03-2014, 08:52 AM   #10090
moparSRT's Avatar
Hey Bill, does the balance stay consistent after a race day or do you rebalance them ??
moparSRT is offline   Reply With Quote
Old 05-03-2014, 08:59 AM   #10091
Honestly, I might check the balance once a month and usually they hold their balance but sometimes the clay might fall off if I get tangled up in lap traffic or take a nasty hit into a wall so it might be worth inspecting your clay at the very least and checking your balance periodically. I guess it's all about how anal you want to be about it.
Old 05-03-2014, 09:05 AM   #10092
moparSRT's Avatar
in off road we would cover the clay with CA glue, that would keep it from falling off, but the tires were done at the end of the day so never bothered to check. Will try balancing some on road wheels
Old 05-04-2014, 04:50 PM   #10093
Trader Rating: 18 (100%+)
Has anyone had the problem of the rear end fish tailing just slightly for the 1st couple of feet when starting at a complete stop?
F14 RJSpeed Legend Losi TEAM REDEYE Yeah I know I can't drive
purpleturk is offline   Reply With Quote
Old 05-04-2014, 08:26 PM   #10094
rear diff is probably too thick... I like to run 80W shock oil in my rear diff.
Also try lowering your rear center of gravity.
Here's what I recently experimented with my TC6 on the rear links and I couldn't get my rear end kick out no matter how hard I hit the throttle in today's racing:
Old 05-06-2014, 08:18 AM   #10095
RussF's Avatar
Trader Rating: 21 (100%+)
Wil
I like the Sorex 28JB for our medium traction carpet. Other guys run the Sorex 32 and have great results also.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
