Like Tree1Likes
Old 04-14-2014, 06:27 AM   #10066
Thanks Yodog. I got the droop set along with ride height its ready to rock this weekend. I think I'll be picking up a new chassis to go under it.
wil
Never give up!
Traxxas Slash 2wd, Spektrum DX4c, Associated B5m
Wil Holmes is offline   Reply With Quote
Old 04-14-2014, 11:25 AM   #10067
YoDog's Avatar
Trader Rating: 26 (100%+)
wil
No Problem...
Good luck with your first day!
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 04-18-2014, 06:25 AM   #10068
Holeshot114's Avatar
Noob problem with steering on my tc6. Ive tried 2 servos and both do the same thing. The problem is after turning left and releasing the transmitter wheel the tires look straight and are. But, when i turn right and release the tires are aimed right just a little. So when driving the car it tracks straight for 10 feet or so then pretty dramatically strays to the right. It is very unpredictable to drive. Any advice?
Holeshot114 is offline   Reply With Quote
Old 04-18-2014, 06:32 AM   #10069
Trader Rating: 25 (96%+)
try removing the servo arm and check for binding in the steering links, with some pliers, pinch any balls that are too tight to reshape the plastic around them so your balls don't get bunched up.
billdelong is offline   Reply With Quote
Old 04-18-2014, 07:38 AM   #10070
YoDog's Avatar
Check to make sure the servo saver spring tension is tight. I always polish my balls with a scotchbright pad and a variable speed dremel. No need to pinch the cups if you do this. Pinching is not reliable nor consistent. There's nothing better than nice smooth, shinny balls.
Old 04-18-2014, 07:51 AM   #10071
Thanks guys, i'll try polishing. Everything seems pretty smooth with no restrictions with the servo disconnected.
Old 04-18-2014, 08:09 AM   #10072
if you are using a plastic servo arm, I'd replace it with an aluminum clamp style horn to eliminate any slop on the servo splines.
Old 04-18-2014, 09:05 AM   #10073
Which servo arm do you recommend?
Old 04-18-2014, 09:19 AM   #10074
I usually buy the generic arms off eBay, only problem is they tend to be a little long and might need to be trimmed to clear the upper deck and/or trim the upper deck to make it fit. You'll need to order the right arm with the correct spline count, for example, my Turnigy 1251TG servos use 25T splines:
http://www.ebay.com/itm/Servo-Arm-Ho...item53ff995e4f
Tekno has some narrow aluminum horns to better clear the upper deck, however you'll need a Tekno ball link assembly instead of a threaded ball stud:
http://www.ebay.com/itm/NEW-Tekno-R-...item43c824c5ae
Old 04-18-2014, 11:55 AM   #10075
Thumbs up
Thanks, i just ordered one. Probably will take a couple weeks, but good price.
Old 04-19-2014, 10:28 PM   #10076
I think i got it figured out. The pin inside the cvd was backed out a little, causing chaos. Thanks to my off road buddies at my local track today!!
Old 04-21-2014, 04:55 PM   #10077
Default Rear end super loose tc6.1 wc
I have a tc 6.1wc that I race 17.5 touring on outdoor asphalt. Car is set up as per manual. Rear end has absolutely no traction. Any ideas? Thanks in advance.
cam345 is offline   Reply With Quote
Old 04-22-2014, 10:57 AM   #10078
YoDog's Avatar
Perhaps the problem is that you have too much steering?
What tires are you using?
Tire prep?
The most common issue I have seen when helping other drivers get their car sorted has been improper droop settings.
One simple test would be to back off your droop screws until they are flush with the bottom of the lower arms. Confirm your ride height is about 5mm all around then drive the car around the track.
If the rear traction comes back, you have found the problem. another thing would be incorrect caster due to confusion with the "c" hub inserts.
Old 04-22-2014, 03:42 PM   #10079
Default TC6.1 pulls hard to the left when I punch it ???
I noticed when I accelerate my car pulls to one side. So much so that it will even sometimes spin out. My LHS shop looked at it but couldn't figure it out. It doesn't seem to be the steering servo as it doesn't do it when I gradually accelerate.
Recently, I was holding my car and I noticed the front, right CVA bone was wobbling when I increased the throttle. So I replaced it with a new spare I had. The car still seems to pull but not as much. Could this be the issue or am I imagining it got better? Any thoughts as to what will cause this and how to fix it ?
- Car: Team Associated TC6.1 (Worlds Car)
- Radio: Airtronics MT-4S
- Motor: Thunder Power Z3R-S 21.5T
- ESC: Turnigy Trackstar 80A Turbo Sensored Brushless
- Servo: Savox SC-1251MG
Nickerz is offline   Reply With Quote
Old 04-22-2014, 03:59 PM   #10080
Could be anything from a seized bearing on one side to poor setup... Etc. Just need to take it apart and inspect every little component for signs of wear
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
