Like Tree1Likes
Old 03-09-2014, 07:44 PM   #10006
dragonracing is offline   Reply With Quote
Old 03-09-2014, 11:10 PM   #10007
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Bgilli26 View Post
Oh alright great, thanks for the input. I really appreciate it. I got a little help at the track last week and it seems to be a little more driveable. Thanks all for the advice.
You can use my setup on petit as we also run on a soda prepped parking lot.
I have been quite happy with the setup and usually make minor changes depending on the traction for a given day.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-17-2014, 10:44 PM   #10008
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
Does anyone have any idea's for more rear steering out of the tc6.1 with the rsd complete conversion.
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 03-18-2014, 05:43 AM   #10009
Trader Rating: 93 (99%+)
You could try a variety of things including thicker rear diff oil and lower roll centers in the rear. You could also try less camber gain, you could also try less rear toe. These qould be somethings I would try. It also depends what class you race as to where the problem is.
thecaptain is offline   Reply With Quote
Old 03-18-2014, 12:08 PM   #10010
What about anti squat? I am waiting more rear steering on power.
Old 03-18-2014, 03:02 PM   #10011
YoDog's Avatar
Anti squat will give you more steering when accelerating. Not too sure what you mean by "rear steering".
You can do things to the rear that will enhance steering like toe, diff stiffness, shocks, springs, roll center, anti squat, etc.
Old 03-18-2014, 08:05 PM   #10012
Hey guys I just got myself a TC6 for VTA racing and my dad bought a TC6.1 for VTA as well. We are planning to be able to share parts so that we aren't buy parts for 2 different cars. In some of my reading I've read that the TC6 will use all the TC6.1 parts, is that true? Also was wanting to put good bearings throughout my TC6 are the RSD bearings suggested or avid?
Never give up!
Traxxas Slash 2wd, Spektrum DX4c, Associated B5m
Wil Holmes is offline   Reply With Quote
Old 03-19-2014, 10:38 AM   #10013
RussF's Avatar
Trader Rating: 21 (100%+)
Some parts are interchangeable on the TC6 and TC6.1 like the aluminum and carbon fiber parts. The 6.1 uses different arms, hubs, etc. You could convert one to the other though but I probably wouldnt mix the parts like having a TC6 front left arm with a TC6.1 right arm.
For bearings, I'm cheap, and ordered the Avid bearings and could not be happier. So far they have worked great. The price was great, shipping was fast, fit was great. I just installed them straight from the package for all my TC6 versions. I bought the kit packages and added a couple extra for my RSD DCJ's.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 03-19-2014, 05:02 PM   #10014
Thanks Russ! I'll post some pic's once I get it.
Never give up!
Old 03-21-2014, 12:16 AM   #10015
Has any played around with anti-squat? I just changed my set-up and put 1 degree of anti-squat im my car. I as this because Im looking for my on power rotation when existing or entering turns.
Old 03-21-2014, 09:00 AM   #10016
Im running 1 deg of anit squat. It helps. Mine has a bunch of steering entry, mid and exit steering. If u get too much try shortening the rear upper links to gain a bit more traction.
Old 03-21-2014, 09:45 AM   #10017
Im have 1 degree of anti squat also but im offset as will. But ive in the rear and both mounts are in the B position. Im hoping this will give me the steering i need! My my home track is 90x50 carpet track. So. The track is fast and sweeping.
Old 03-22-2014, 03:26 AM   #10018
jpx
jpx's Avatar
So when you guys talk about anti squat you are talking about the front I guess.
Are you still using the 4 c-hubs so you run with a caster of 3 or did you change to 6 hubs and get a caster of 5?
Greetings, JP
jpx is offline   Reply With Quote
Old 03-22-2014, 04:54 AM   #10019
Greetings, JP
Anti squat is rear. Referring to the angle of the pin when the front mount is higher. Kick up and anti dive are the front.
Old 03-22-2014, 03:54 PM   #10020
Will be posting soon rsd tc 6.1 with spares...just a heads up
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
