Like Tree1Likes
Old 01-28-2014, 06:30 PM   #9946
tc6.1's Avatar
does anybody race at trains&lanes if so what is the gearing for vta and a good starter esc and motor for vta
tc6.1 is offline   Reply With Quote
Old 02-07-2014, 06:16 AM   #9947
Trader Rating: 34 (100%+)
Just finished a used tc6 build and Im getting some dogwalking out of the back end. Anyone shed some light on how to get that out? Car is square, wheel base is equal.
Race19s is offline   Reply With Quote
Old 02-07-2014, 07:29 AM   #9948
Chaz955i's Avatar
Are you using the plastic shims used to set the rear toe/trackwidth? If so get rid of them and get a couple packs of the aluminum Associated 12R5 front ride height shims and use those. Those plastic clips distort under pressure and it is really tough to get an equal setting left to right. Second double check your chassis plate is flat. My TC6 would tweak fairly easily. I'd take off the wheels and put the car on a flat surface and while applying downward pressure to the front and rear bulkheads I'd retension the top deck. This usually worked to take out the chassis twist. Check for tweak and you should be close if not where you want to be. Good luck.
Chaz955i is offline   Reply With Quote
Old 02-07-2014, 07:50 AM   #9949
YoDog's Avatar
Trader Rating: 26 (100%+)
What do you mean by "dog walk"?
It's true that the plastic spacers are junk but you should also get the TC6.1 arm mounts which have the 2mm offset mounts. Since you will likely use 2mm in both front mounting points as well as the far rear for toe in, just use the offset pieces to eliminate the shims all together.
What surface are you running on?
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 02-07-2014, 08:24 AM   #9950
By dog walk, its like an old crappy pick up truck. the rear wheels dont follow in the track of the fronts, they are slightly right of the front track, giving a diagnal look. We run indoor carpet, low/med grip. Thanks
Old 02-07-2014, 11:34 AM   #9951
YoDog's Avatar
I see... Are both rear wheels offset to the right? Quite often the front and rear track width are a little different depending on the setup. The car will wander side to side a little at slow speeds due to the rear toe but is unnoticeable at speed.
Old 02-07-2014, 11:26 PM   #9952
I got lucky enough that I have been handed down a floating servo mount. Can anyone post the screw sizes needed to complete the install? I have some pics from here on the install, so should be good. Also, anything special that needs to be done for the servo turnbuckle mounting? Appreciate your input. Thanks.
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
Old 02-08-2014, 07:44 AM   #9953
HA! I found the answer aways back here on the screws. Now if I could get any info on this servo saver replacement, I will be golden.
Old 02-08-2014, 10:54 AM   #9954
rc car guy's Avatar
Check for tweak and make sure shocjs are built properly are you running out in the fluff when this happens make sure every thing is equal on thr car
rc car guy is offline   Reply With Quote
Old 02-08-2014, 01:01 PM   #9955
Trader Rating: 58 (100%+)
Can anyone give me a good starting setup for 25.5 vta. My friend just bought a tc6 and this is his first time racing one. Thanks for the help.
Radical Motors
gotnitroonline.com
In Memory of Shaun Neary
lucky 13 raceway
robertsmalibu is offline   Reply With Quote
Old 02-08-2014, 09:48 PM   #9956
YoDog's Avatar
Is this the R-Factor RC servo mount and saver set? If so you will need 1 ball cup from the B4 or T4 links to make the turnbuckle the right length and a ball stud with the threads cut short enough to be flush to the top of the servo saver. I can send you some pics if need be.
By the way guys, I have 25 more mounts nearly ready for order. Just need to anodize the blocks and package them up.
Old 02-08-2014, 10:55 PM   #9957
It is one of yours. I have the AE ball stud cup and going to use it to lengthen the existing turnbuckle. I am also using the existing ball cup that was on the servo savor and attached it to the bell crank. I will test tomorrow for clearance and length. I will appreciate the pics of the servo saver.
Old 02-09-2014, 09:16 AM   #9958
YoDog's Avatar
I'll try to take some new pics today and get them posted up.
Old 02-09-2014, 08:52 PM   #9959
So this is what my final looks like. Appreciate any comments before I put it on the track.
http://www.rctech.net/forum/members/...rvo-mount.html
On a side note, my Only concern is that the belt seems to rub against the mount. Any ideas on a fix/correction?
Old 02-09-2014, 09:07 PM   #9960
YoDog's Avatar
Looks good! That one is one of the very first mounts I made. Although the belt touches the block, there is no tension on it so I found that it caused no problems. Keep in mind that the way you have the turnbuckle attached, there is no longer a servo saver function because you are attached directly to the steering crank. You may want to install a servo saver on the servo. I made replacement saver cams but it may be awhile till I can have more made.
The latest mounts have more offset to give the belt more clearance and the top plate is smaller with a bump to act as a battery stay.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
