Old 12-30-2013, 10:27 AM   #9901
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by flag72 View Post
I guy's
well I bought a TC 6.1 WOLRD for VTA racing , one thing it as NO spool front Diff it as been replace by a Gear Diff. will this work fine or should I look for a Spool Diff...
whats a good replacement for this part (front Spool)
thanks
Danny
The diff will be better for VTA anyways so just experiment with heavy diff goo.
500K to 1.5 million cst will work well. Later you will want to find a slipper spool for the TC6 and use that in conditions that need a locked up front end.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-30-2013, 10:40 AM   #9902
Trader Rating: 18 (100%+)
thanks YoDog
can you give me the part number for those heavy GOOP...
again thank you
Danny Flag
flag72 is offline   Reply With Quote
Old 12-30-2013, 10:54 AM   #9903
Originally Posted by YoDog View Post
Is the belt rubbing on the top deck? That's weird!
I know it's close but mine are not that close. The deck is not spaced up from the spur/pulley blocks, right?
Just looked. Doesn't look like it to me.
lee111m is offline   Reply With Quote
Old 12-30-2013, 11:06 AM   #9904
nsgland's Avatar
Trader Rating: 19 (100%+)
thanks YoDog
again thank you
Danny Flag
This should help.
http://www.tqrcracing.com/shop/produ..._keyword=putty
http://www.amainhobbies.com/product_...-500000wt-40cc
NSG Racing
Tamiya TA05 V2
Futaba,Tekin,Savox,LRP,Exotek,Sorex,Alpha
CapeFearRaceway.com
nsgland is offline   Reply With Quote
Old 12-30-2013, 11:15 AM   #9905
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
YoDog, any floating servo mounts yet?
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 12-30-2013, 11:25 AM   #9906
Rick Hohwart's Avatar
thanks YoDog
again thank you
Danny Flag
These work well also:
Gravity R/C Heavy Weight Silicone
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-30-2013, 11:32 AM   #9907
I've looked at raising the from diff, but i dont think that will give it enough clearance. Front diff is currently as low as it can be.
Old 12-30-2013, 02:00 PM   #9908
YoDog's Avatar
If that's the case, you should run the diff at the stock recommended height. It will help but something doesn't look right still. It's as if the top deck is higher than normal. One good thing is that there is no tension on the top side of the front belt under acceleration. How's the belt tension at rest, tight or loose?
Old 12-30-2013, 02:13 PM   #9909
wtcc's Avatar
Is it rubbing when you turn the pinion or do you see marks on the top deck?
If it is just the marks, then don't worry.
If not, check if the car is build like the manual suggests. Maybe the old owner did some changes...
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 12-30-2013, 06:47 PM   #9910
YoDog's Avatar
I got a quote for the blocks yesterday and I think it's pretty fair so I may be pulling the trigger on another 30 servo mounts soon. The saver cams are a different story so if someone has a machinist who might be interested in making them and splitting the proceeds, I will be happy to share the Model files. Otherwise, we could always just use servo mounted savers instead.
Old 12-31-2013, 08:50 AM   #9911
would the LOSI silicone Diff lube do the same job,and is less expensive.If so which grade LOSI DIFF lube would work compare to CST lube...
thanks for all the help and Happy New year to all
Old 12-31-2013, 09:32 AM   #9912
OfnaJoe's Avatar
LMK when and where to send the money
Old 12-31-2013, 09:58 AM   #9913
Scottmisfits's Avatar
Not sure if Losi makes anything 1 million and higher. If they do, it will work. This stuff, at least from Gravity, has a consistency thicker than molasses, and that's only the 1 million that I have.
Scottmisfits is offline   Reply With Quote
Old 12-31-2013, 11:01 AM   #9914
I did raise it. the belt seems to be decently tight. Haven't had an onroad belt drive so I'll probably have the guys at the track give it a once over next time I go. Thanks for the help guys.
Old 01-06-2014, 08:49 AM   #9915
well I got my TC 6.1 car and its in great shape ( bought use).this will serve as a VTA racer how well will the front Spool work in VTA.or should I look for a front DIFF...
thanks
Danny
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
