Like Tree1Likes
Old 12-11-2013, 08:10 AM   #9841
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rc car guy View Post
On a different note how are those aluminum screws in the top deck and bulkheads holding up? Do you have them on he underside of your car and how do you like your orca motor? 1
They are Ti screws from Gravity RC. Seem to be fine. Not sure how much lighter they are. With a LW Speed6 I'm at 1380g. Orca seems decent, always trying different motors. Has better bottom end punch than my previous D3.5, and doesn't seem to fade at higher temps.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 12-11-2013, 08:22 AM   #9842
rc car guy's Avatar
sweet i have one coming are you running the ht rotor or stock? also how do you think alum screws would hold up, im at 1386 but most of the weight to be lost is in the body but id rather put steel screws into the buttom side of the card to add weight there than it up top on my body haha
rc car guy is offline   Reply With Quote
Old 12-11-2013, 08:28 AM   #9843
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by gearit View Post
Does anyone have or know where I can find a setup for VTA for aTC6.1. I run carpet with tight turns and I'm trying to get my car to roll through the turns better. Thanks
I've always kinda liked the box stock setup for VTA, but I did add a gear diff in front.
Seems to me that Darkside posted his VTA setup one time, or if you PM him he will send it to you.
I'm pretty sure I've found some other VTA setups posted in this thread but it would require some searching around.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 12-11-2013, 08:30 AM   #9844
Dan Hamann's Avatar
12.5 rotor. Aluminum screws is something up to the individual. I've had them , never had issues. Some guys I know have had nothing but issues with aluminum. Probably wise to run Ti or Steel through high stress areas to prevent busting off screws, especially if the car sees a lot of impacts.
Old 12-11-2013, 08:50 AM   #9845
Rick Hohwart's Avatar
This is Myron Kinnard's TC6 setup for VTA. It should get you pretty close.
Myron Kinnard - TC6 VTA
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-11-2013, 08:59 AM   #9846
rc car guy's Avatar
ya i currenty only have them in the plastic portions
cut like 10grams out of the car just by that so far
Old 12-11-2013, 10:36 AM   #9847
thanks, I will give it a try
gearit is offline   Reply With Quote
Old 12-11-2013, 10:54 AM   #9848
Adonis_mp's Avatar
just the part number no reason
Not sure that I aggree, if you look at each end, it has a diffrent number. I don't have a picture of the one i have but if you look at the once on amain, you can see the #3 on one and #14 on another. I also know that there are other numbers because I separated the once I have by the number and had about 5 diffrent groups.
I have Job Security, nobody wants my Job!!!!!
Losi 22-4 - MMP - Tekin Gen2 5.5 * Losi SCTE - RX8 - Tekin Pro4 4600 * 22SCT - MMP - Tekin Redline Gen2 6.5T * Losi 22B 2.0 - Tekin RS - Novak 8.5T * TC6.2 * TC6.1 VTA * Wraith - CC Sidewinder - HH TorqueMaster 35T * E-max - Rustler - Slash - 1/16 Revo
Adonis_mp is offline   Reply With Quote
Old 12-11-2013, 01:28 PM   #9849
edonsohc's Avatar
could be a cavity number. most injection molded parts have more than one part in the mold. something that small is probably around a 24-32 cavity mold.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 12-11-2013, 03:17 PM   #9850
Michael@USPN's Avatar
Thats exactly right. Theres a total number that they come in and they are just marked out of which one they are. Nothing special.
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 12-15-2013, 02:57 AM   #9851
Old 12-15-2013, 02:58 AM   #9852
Just wanted to say thanks to A. Brumblay, R. Hohwart, Evo Chick and some of the others who had mentioned on how to get rid of the slop/(wear and tear) from a full season of racing. I got my slop out of my tc 6.1wc and the car has come back to life for me
Here's a video of my tc 6.1wc being a very competitive car to a lot of other great manufacturers out in the field. For being a very reasonable priced car....it can win baby
This was our toys for tots final major race of our season at Norcal Hobbies.
My car is in tq position. Pink car.
https://www.youtube.com/watch?v=KHzJ...e_gdata_player
I know I did some mistakes, but it wasnt the cars fault. I still have much work to do.
Thanks Jon Johnson for the video, and all the great guys at Norcal Hobbies.
Old 12-17-2013, 06:09 PM   #9853
i have a 6.1wc and was wondering what's a good track width to run F/R for 17.5 blinky and what's the best way to shim, at the arms or hexes thanks in advance
quinnfrazier is offline   Reply With Quote
Old 12-18-2013, 08:00 AM   #9854
YoDog's Avatar
Trader Rating: 26 (100%+)
Shim at the arms to get the desired track width but you can use wheel shims to test and fine tune. In the front, use the offset blocks and add up to 1.5mm if needed. In the rear, use the offset blocks for the back mount and the standard block for the forward mount. You can add up to 1mm here as well.
When at all possible, shim the arms and use the wheel spacers only for a quick adjustment at a race event. IMO
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-18-2013, 08:20 AM   #9855
rc car guy's Avatar
makes sense but why do you say the measurements is that what makes the car 190 mm?
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
