Like Tree1Likes
Old 11-29-2013, 08:58 AM   #9811
Trader Rating: 25 (96%+)
maybe consider a dual fan mount with one of the fans directed on the end bell?
http://www.integy.com/st_prod.html?p...8#.UpjHYOKozKE
billdelong is offline   Reply With Quote
Old 11-29-2013, 02:48 PM   #9812
Originally Posted by rc car guy View Post
right so would it be better to run a heat sink, and a fan? i have an apex 2 or something like that, with no vent holes i believe so that isnt a viable option at the moment. also i have non anodized and anodized heat sinks (different colors, and sizes). and what about direction towards the motor(infront or behind) which is better?
I use two fans, one in front and one behind. Works really well for 17.5 motors where heat is usually an issue.
jha07 is offline   Reply With Quote
Old 12-02-2013, 07:27 AM   #9813
edonsohc's Avatar
what's a good rear diff fluid weight to run? I've seen lots of different fluids on numerous setup sheets. i'm running vta and sometimes usgt on carpet. mine developed a leak and now has no fluid. I don't know what was in it as I bought the car used. thanks.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 12-02-2013, 09:05 AM   #9814
Michael@USPN's Avatar
There was another post above this one in regards to having the heat sink with the fans. I First started out like that but it honestly didn't compare to the 30mm fans that are out there now specifically made for rc cars. Like the R1 wurks fans. No camparison to what I was running b4. I use that as an example and others I'm sure will chime in on other 30mm fans. Many other top racers use this type of setup at norcal hobbies plus its roar approved. Im pretty sure two fans are NOT roar approved. But if you're not racing that kind of races then you don't have to worry about that. Again though the one 30mm fan are much more effective then the heat sink two low output fan setups. I Do recommend trying out the R1 wurks fans as they are the very strong/very well might be the strongest and less expensive. Hope this help out.
Now to the gear diff oil for your VTA...I Don't run VTA. I Run 17.5 blinky. I'm sure its not too far off. But the ranges do vary from 450 cst to 1000 cst. I personally have found that I like a lighter diff oil for a quicker rotation into the turns. The lighter the diff oil the easier the car will turn in. But I'm told the heavier the diff oil the better exist speed you will have. I personally like the better turn in, n haven't really notice a significant amount of loss in exit speed. What I would suggest to you is, talking to the top vta racers there n see what they use for a similar car Hope that helps bud. Good luck!
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 12-03-2013, 08:17 AM   #9815
rc car guy's Avatar
So I have read that 6.1 battery and servo dont flex with the chassis what would the car do if I made it able to more traction? Or somethijg like that?
rc car guy is offline   Reply With Quote
Old 12-03-2013, 08:28 AM   #9816
rc car guy's Avatar
I think im running 2k in mine seems to work well and if that doesnt work thinner=more corner steering and higher weight= more high speed steering less turn in steering
Old 12-03-2013, 09:21 AM   #9817
YoDog's Avatar
Trader Rating: 26 (100%+)
This is not quite true. The chassis does flex under the battery and servo, it just doesn't flex symmetrically. A floating servo mount will give you more room to place your electronics and move some of the weight forward on that side of the chassis. It also places the mounting point at the center of the chassis which allows the chassis to flex more equal from left to right. The purpose is not for more traction. These methods are for allowing better balance and a more consistent tuning window. The primary purpose for increased chassis flex is to create a wide tuning window which makes the car easier to setup and drive.
A stiff car will usually be faster but it's much harder to find the "sweet spot".
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-05-2013, 07:28 PM   #9818
rc car guy's Avatar
hm alright well i will keep that in mind and test with that tomorrow, cars on rails now super fast, and super good
has anyone thought of making less rotating mass parts such as the spur gear mounts? or better/ lighter cva's
Old 12-06-2013, 10:57 PM   #9819
rc car guy's Avatar
does anyone know of a titanium/aluminum screw kit for the 6.1? other than associated kit i want it to be lighter than the stock screws. also i hear that the alum. screws that go into alum. can sieze anyone have any suggestions on how to stop that from happening
Old 12-07-2013, 12:24 AM   #9820
wtcc's Avatar
Don't worry! I use AE's aluminium screws everywhere in my car (except for armmounts and motor) and didn't have a problem for the last two years. You only have to accept that you cannot use brutal force to tighten them. For maximum weight reduction add AE's titanium ballstuds to your car.
Haters will tell you aluminium screws are to weak and will not work bla bla, but it is simply not true
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 12-07-2013, 12:46 AM   #9821
rbarciko's Avatar
You can get titanium screws, but they are expensive:
http://www.lunsfordracing.com/mm5/me...de=CARS-ASTC61
I personally use steel screws:
http://www.zzracing.net/stainless-st...c61-p-292.html
And reduce the 10-30 grams of weight you would save some other way, such as using a light weight body shell (painted lightly also):
http://racepf.com/touring-car-190mm/mazdaspeed-6-light/
-== Robert Barcikowski ==-
TFTR TC6 F104v2 RC Parts Search
rbarciko is offline   Reply With Quote
Old 12-07-2013, 06:38 AM   #9822
YoDog's Avatar
I have personally used the ZZ Titanium screws with good results and they are less expensive than the AE aluminum screws. As with any light weight screws, it is best not to over torque them as the heads strip easier than steel. Use a hi quality, well fitting driver to lessen this possibility.
Old 12-07-2013, 06:42 AM   #9823
YoDog's Avatar
It's true that a light weight body makes a big difference. I have had no real change in durability since switching over and since my cars handle better, I crash far less. ;-)
Old 12-07-2013, 07:05 AM   #9824
rc car guy's Avatar
I had a fairly new ltc r light weight body and it got trashed even with shoe goo and dry wall tape so I can reduce the weight sone but I was still interested I need about twenty grams lost but I can save some more wire just have to make sure that its balanced again
Old 12-08-2013, 07:16 PM   #9825
rc car guy's Avatar
anyone have a super clean super minimalistic wiring job and what do you guys think of 14gauge instead of 12 guage wire?
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
