Like Tree1Likes
Old 11-21-2013, 02:25 PM   #9781
evochick's Avatar
Originally Posted by thejo3 View Post
Would the pro shock springs long (YS-14575L) work right away on AE's VCS3 shocks or we need to buy something else ?
Nope they wont fit the yokomo springs are bigger in diameter, but not much,
you will need different adjusters and seats, im not sure if the yokomo ones fit ??
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 11-23-2013, 02:30 AM   #9782
Think I have a big enough pinion gear?
62t spur and 45t pinion for that glorious 2.75:1 FDR.
Scooter79rs is offline   Reply With Quote
Old 11-23-2013, 02:30 AM   #9783
Double posted.
Old 11-23-2013, 09:58 PM   #9784
rc car guy's Avatar
so guys i took a break from onroad racing and i recently started again, i have a tc6.1 not worlds car, any secrets that i should know?
rc car guy is offline   Reply With Quote
Old 11-23-2013, 10:27 PM   #9785
Logi Maker's Avatar
Trader Rating: 49 (100%+)
The Tamiya ones fit but you MUST use the Tamiya orings in the collars... the AE ones will not work. Also HPI spring cups..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-23-2013, 10:30 PM   #9786
Logi Maker's Avatar
I got some 55T 48P that look smaller than the pulleys! Got them back when they weren't making pinions bigger than high 30s...
Kyle Predmore
Old 11-24-2013, 12:09 AM   #9787
wtcc's Avatar
RSD bladders and their range of springs and pistons are a worthy upgrade. Depending on the class you drive I would also go for a gear diff in front. To reduce slop in the suspension you can glue the inserts to the hubs and put in a grub screw from underneath.
Other than that the car is pretty awesome
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-24-2013, 08:14 AM   #9788
rc car guy's Avatar
I have the serpent springs and the rsd ones dont allow rode height unless they changed them and I found out hr hard way to glue the inserts thanks
Old 11-24-2013, 09:59 AM   #9789
wtcc's Avatar
RSD has normal and short springs for the TC6. Sorry to hear you wasted your money...
The slop in the new plastic sucks! After some months I ignored the slop and just drove it like they sell it. The car is not slower because of the slop. Still fast enough to beat the newest designs out there
Old 11-24-2013, 10:02 AM   #9790
rc car guy's Avatar
true story a buddy of mine who is a better driver than me in my opinion, not his. has the new mi5 he set up my car ive been running the lay out, but not tc in like a year, i ran twice once in the third heat, and once in the main i was only .1 off oh his fast lap, and i was still learning, the car could use a bit more improvement but it was good for just throwing it down. its still very competitive
Old 11-25-2013, 09:33 PM   #9791
Adonis_mp's Avatar
Default WTB parts
I want to build a VTA ON THE cheap with extra TC6 part that i already have but I'm missing a few. I posted this on the want to buy but I'm sure nat everyone looks there, I just noticed it myself. You may have these in you parts box so I'm looking to buy the following parts:
Team Associated Bulkhead (4) [ASC31309]
Clamping Wheel Hex (Blue) (2) [ASC31234]
steering bellcrank post insert only
Spur Gear Hub [ASC31314]
Spur Clamping Ring [ASC31319]
20T Spur Pulley [ASC31320
Pm with price with shipping.
I have Job Security, nobody wants my Job!!!!!
Losi 22-4 - MMP - Tekin Gen2 5.5 * Losi SCTE - RX8 - Tekin Pro4 4600 * 22SCT - MMP - Tekin Redline Gen2 6.5T * Losi 22B 2.0 - Tekin RS - Novak 8.5T * TC6.2 * TC6.1 VTA * Wraith - CC Sidewinder - HH TorqueMaster 35T * E-max - Rustler - Slash - 1/16 Revo
Adonis_mp is offline   Reply With Quote
Old 11-26-2013, 11:17 AM   #9792
IndyHobbies.com's Avatar
Anyone know of a source for aluminum steering knuckles for the TC6/TC5? Integy used to make a set, but they are discontinued. Bummer. One of mine got stripped out.
I've looked at Tower and on ebay. Maybe there's another source?
Thanks,
Scott
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-26-2013, 01:39 PM   #9793
rc car guy's Avatar
Thanks,
Scott
you could always drill the hole out and retap it with a bigger threaded screw, you could go to a 4/40 i think thats bigger than the 2.5 mm, it uses, or you could try some red lock tight, or even superglue, or a longer bolt and a nut on the bottom assuming it wont rub.
Old 11-26-2013, 03:00 PM   #9794
nsgland's Avatar
Trader Rating: 19 (100%+)
Thanks,
Scott
Not sure if these will work for you. Here is the link.
http://www.integy.com/st_prod.html?p...6#.UpUnYScliRM
NSG Racing
Tamiya TA05 V2
Futaba,Tekin,Savox,LRP,Exotek,Sorex,Alpha
CapeFearRaceway.com
nsgland is offline   Reply With Quote
Old 11-26-2013, 03:28 PM   #9795
Trader Rating: 25 (96%+)
says "restock pending" ... maybe they're not discontinued after all?
I also wonder if the aluminum bends instead of breaking, wouldn't that be really hard to hold a tune?
billdelong is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
