Old 09-12-2013, 08:52 AM   #9601
alonzo's Avatar
Guys,
I've got a question regarding setup tools. More specifically a setup board. I would think it important to make sure that the board is level, but i'm seeing some that don't have any adjustment on them (just "bumper" feet). I've ordered a couple different models of the Integy board and even though they are advertised as having spring loaded adjustable legs, the ones I received just had bumper feet.
Any recommendations?
Thanks,
Zo
RC America - Hudy/Xray - Express Motorsports - Hyperdrive - BSR - Novak - Xtreme RC Racing - Boca Bearings - USVTA Member#123 - Xray fan boy
Engineering is like math.....Only louder.
alonzo is offline   Reply With Quote
Old 09-12-2013, 12:08 PM   #9602
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by alonzo View Post
Guys,
Thanks,
Zo
Some setup boards have a bubble level because they use gravity based gauges.
Most setup gauges are not like this. The most important thing is flatness and durability. Everything else is icing on the cake. I actually have the integy setup board but don't even bother with the setup gauges that came with it anymore due to the fact that they are gravity based. Stick with either a Hudy or a similar knockoff.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 09-12-2013, 02:33 PM   #9603
JustWill75's Avatar
Send a message via AIM to JustWill75
Originally Posted by tech9 View Post
Thanks...I really wanted to know if they fit the TC6.1 though.
Get the Reflex Racing set. I've been using them for 2 months and haven't have problems yet.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 09-12-2013, 05:51 PM   #9604
YoDog's Avatar
Originally Posted by wtcc View Post
I heard from a friend in the industry that they are working on it for several months, but never actually saw anything...
I would be in a market for one even though anything we have seen from other companies made no difference in performing better on track regarding laptimes only. AE made a huge step from TC5 to TC6. The car drives much better and is easier to handle on the limit. I am not sure if it makes sense to offer another normal chassis like everyone else (short shocks, floating servo mount, etc.). What I would like to see is a manufacturer focussing his efforts on the suspension and not on chassis flex characteristics as there is much more time gain potential hidden there...
So I am hoping for a revolution while expecting the boring standard.
Some of the AE Team guys were trying some prototype stuff at RROC last May.
Don't be surprised if the new kit uses dual crank steering. It may have a floating servo mount considering the trend and I know they were trying out some various aftermarket options. The car is in need of redesigned shock towers too. Maybe even short-hi volume shocks as well.
Old 09-12-2013, 06:14 PM   #9605
YoDog's Avatar
Originally Posted by bertottius View Post
It's for 17.5 at Wagner. Seems like no matter where I make adjustments, the car is on ice. If you're at the track tomorrow, I'll show you.
Usually if the car is that much of a handful, there is usually a fundamental setup problem. If the droop vs ride height is bound up, you will have big problems. If you are loose off power or under braking, too much weight is being transferred to the front of the car either because the front springs are too soft or there is too much rear droop or none at all (bound up). I typically run (0) arm hangers in the upper hole all around with offset mounts all around on the front arms and just the back positions on the rear arms. Standard offset at the front of the rear arms.
Try 2* rear camber and 1.5* in the front. What tires are you using and are you saucing the tires?
Take a look at my setup on Petite RC. I have been using it all summer with great results.
Old 09-13-2013, 12:26 AM   #9606
wtcc's Avatar
That would suck! My hole RSD line of springs = useless
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 09-13-2013, 02:04 AM   #9607
Originally Posted by jonston View Post
doe anyone know if associated is working on a new car? or its on the back burner at the moment? im doing really well with my worlds car but I feel its bit behind, design wise with other manufacturers.
I have moved on from my TC6.1 Worlds simply because I felt I was starting to lose out due to the car not being up to other manufacturers newer models. But I still lurk about here watching to see if a new Associated car is coming and what it may have on it. It would be good if Associated would start to let a few things slip out to build up some momentum behind a new car or even that there is one coming. I know some people will say the TC6.1 is a good car and I do agree but to stay at the top you need to keep the innovation going.
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
Old 09-13-2013, 10:48 AM   #9608
YoDog's Avatar
One should keep in mind that releasing information too soon is bad for business.
If you have a shelf full of current product and they are still selling well... telling the public about a new model will dramatically reduce the demand for the current product. The manufacturer will then need to reduce the price just to entice the public to continue to buy the current product at a loss. You can be sure that AE will release a new car based on their development business model. It has worked well for them in the past and there is no need to change that strategy. When the new car is ready, an announcement is usually made considering that the kit is already in mass production to fill the demand, post announcement. AE is already an established manufacturer so there is really no need to create buzz. If they build it... people will buy it.
Old 09-13-2013, 10:52 AM   #9609
YoDog's Avatar
No need to panic... I'm just speculating.
From what I hear, the short shock setup may not have an advantage anyway.
Time will tell I suppose.
Old 09-13-2013, 11:34 AM   #9610
kewdawg's Avatar
jonston and scoyle, exactly where is it you think the car is loosing out??? Are you simply basing this on newness of design or kit??? My TC6.1 handles just as well or better than any of the other brands. Set-up is always the key.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 09-14-2013, 01:28 PM   #9611
syndr0me's Avatar
Trader Rating: 32 (100%+)
Wot is this?!
http://www.cambergain.com/post/61222...6-1-with-a-two
syndr0me is offline   Reply With Quote
Old 09-14-2013, 01:50 PM   #9612
vivo quevas's Avatar
Trader Rating: 17 (100%+)
Originally Posted by syndr0me View Post
I call it interesting!
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 09-14-2013, 02:41 PM   #9613
Trader Rating: 21 (100%+)
wow, nifty. Looks like an Mi5/TC6 hybrid
silencery is offline   Reply With Quote
Old 09-14-2013, 03:13 PM   #9614
wtcc's Avatar
Very good! Awesome low budget idea. Cutting a topdeck in half and installing it that way. I may try that as well
AE / Reedy / RSD
Old 09-14-2013, 03:22 PM   #9615
Potoczak's Avatar
Trader Rating: 107 (100%+)
Hmm interesting.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
