Like Tree1Likes
Old 07-31-2013, 09:17 AM   #9496
Rick Hohwart's Avatar
Originally Posted by wtcc View Post
I hope you enjoyed this.
Awesome!
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 07-31-2013, 09:38 AM   #9497
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Or why not just sell a kit
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 07-31-2013, 11:53 AM   #9498
What about rear body mounts?
Serzoni is offline   Reply With Quote
Old 07-31-2013, 12:33 PM   #9499
YoDog's Avatar
Trader Rating: 26 (100%+)
Is there potentially a class for this configuration here in the U.S.?
What about tires...foamies?
I'm in for designing a kit if the numbers make sense.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-31-2013, 12:43 PM   #9500
patorz31's Avatar
YoDog any ETA on the servo mount kits and the new motor mount?
patorz31 is offline   Reply With Quote
Old 07-31-2013, 12:51 PM   #9501
YoDog's Avatar
I Just started a new job so I no longer have machine shop access.
I can still design parts but it will be awhile till I can get back to making parts.
If someone knows of a shop that is willing to do small runs of parts at a low cost, I may be interested in farming the work out.
Old 07-31-2013, 01:48 PM   #9502
wtcc's Avatar
You can use the front or rear shocktower and fix it to the rear bulkheads with body mounts from a pancar or else.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 07-31-2013, 03:28 PM   #9503
wtcc's Avatar
Jupp, foam tires. It is the only choice for my outdoor hometrack. I discovered this conversation because I am still waiting for a RC10R5.1. I want to use this chassis for our F1 class and as the front needs to be low I tried some things and this just developed step by step in front of me.
Here is the still unfinished car:
It will become a Brabham BT-45b. Still have to think about the rear body posts (and have to look what I have lying around). I can't wait to drive this thing. Hopefully it will give the feedback of a real seventies F1-car
AE / Reedy / RSD
Old 08-01-2013, 03:24 PM   #9504
steveo561's Avatar
Default new guy used tc6.1
Hey everyone just got a nice used tc6.1 and in a day or so will be getting what ever info from previous owner on the car I can to help dial my car in. All what these new car can be chaged and adjusted is a little overwhelming. So I am sure to be jumping in on this forum quite frequently- im sure u guys have link to a set page or general info u could hook me up with
steveo561 is offline   Reply With Quote
Old 08-01-2013, 05:22 PM   #9505
bertottius's Avatar
Trader Rating: 17 (100%+)
There are several setup sheets on the Team Associated web site.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 08-01-2013, 08:12 PM   #9506
nsgland's Avatar
Trader Rating: 19 (100%+)
Here is the link for the setup sheets.
http://teamassociated.com/cars_and_t...anuals_setups/
NSG Racing
Tamiya TA05 V2
Futaba,Tekin,Savox,LRP,Exotek,Sorex,Alpha
CapeFearRaceway.com
nsgland is offline   Reply With Quote
Old 08-01-2013, 08:24 PM   #9507
nsgland's Avatar
I picked up a 6.1 a couple weeks ago and am having one problem. The problem is steering CVA bind. I have to dial out a whole lot of steering to get rid of the bind. Is there a fix for this problem other than buying Reflex DCJ's. I'd like to be able to use all or most of the steering that should be available on the car.
Thanks,
Neil
NSG Racing
Tamiya TA05 V2
CapeFearRaceway.com
Old 08-02-2013, 12:50 AM   #9508
Kellen Guthrie's Avatar
Thanks,
Neil
I haven't had any problems with them binding so far. Make sure they're greased enough. Other than that you might just want to pick up dcjs.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 08-02-2013, 08:06 AM   #9509
Thanks,
Neil
The chatter does not seem to affect the car on the track when it is under load so I would not hesitate to use full steering. Of course if there is some problem with the drive shaft itself then that must be fixed.
DCJs will eliminate the chatter. Using a gear diff will as well.
www.reedypower.com
Old 08-05-2013, 02:50 PM   #9510
YoDog's Avatar
Thanks,
Neil
You may possibly be too narrow as well. Use the offset arm mounts or have about 2mm spacing if using the standard mounts.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
