Old 07-26-2013, 08:50 AM   #9466
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by chevtech23 View Post
+1 on Bobs setup, but be aware you may have to grind on the steering arm to get it to clear the upper deck for clearance. I left mine at 2b.
+1 to you ON leaving the steering in the 2b setting I set mine up like Bob had it and my steering was in a bind so I change it back to the standard setup and the car was good. This week I'm changing the shock oil to 45 in front 40 in rear since it will be 103* at the start of practice but by the time we run the mains it will be 11 pm and the airtemp will still be 90*.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 07-26-2013, 09:08 AM   #9467
bertottius's Avatar
Trader Rating: 17 (100%+)
Anybody know where I can find the silicone ear plugs for the trannies?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 07-26-2013, 09:28 AM   #9468
Rick Hohwart's Avatar
Walgreens
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 07-26-2013, 09:37 AM   #9469
bertottius's Avatar
Originally Posted by Rick Hohwart View Post
Thanks Rick. I never used these before. You just throw them in?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 07-26-2013, 10:01 AM   #9470
Kellen Guthrie's Avatar
Originally Posted by MDawson View Post
Check the servo saver to see if it has loosened.
I'm sorry is meant it has a ton of exit oversteer.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 07-26-2013, 10:11 AM   #9471
Take a small piece out of the ball and then roll it into a thin rope and shove it into the gears make sure you get it into all the gears.
Old 07-26-2013, 10:15 AM   #9472
bertottius's Avatar
Ok cool. Thanks!
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 07-26-2013, 10:34 AM   #9473
YoDog's Avatar
Trader Rating: 26 (100%+)
You may not have enough weight transfer to the rear when accelerating out of the corners. Add more droop to the front and go lighter on the front shock oil.
What settings are your arms at? Keep in mind that Rick's setup for NorCal is basically medium grip on a smooth outdoor surface. ( sometimes a bit dusty) If I recall correctly, the track down south has mad grip so you will need to be set up with less steering bias.
Less rear droop and more front droop will help. Like I've said before, it's all about weight transfer. You have to understand and control how the weight moves from front to rear (most important) and side to side. Once you get that sorted out, geometry and all the other changes will have a more obvious effect.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-26-2013, 10:35 AM   #9474
YoDog's Avatar
Originally Posted by CL View Post
2 Weeks...
My favorite quote from "The Money Pit".
Time to completion is always "2 weeks"
Old 07-26-2013, 11:09 AM   #9475
Yeah I was thinking about softening the rear, more front droop, or adding more rear camber. But it almost seems like the car is just diffing out on exit. I'm going to do some testing today to figure it out.
LRP America
Old 07-26-2013, 11:11 AM   #9476
wtcc's Avatar
Two weeks before christmas?
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 07-26-2013, 12:48 PM   #9477
You have to place it a little bit at a time. it works out to about 75% of one plug. I weighed what I put in and it is about 3g.
www.reedypower.com
Old 07-26-2013, 12:52 PM   #9478
bertottius's Avatar
Ok that makes sense. Thanks Rick.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 07-27-2013, 07:16 PM   #9479
mtbboy's Avatar
Hey.
What does a 1 mm shim equal to where the rear toe is concerned?
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 07-29-2013, 08:50 PM   #9480
Trader Rating: 63 (100%+)
I just bought a tc6.1 off of ebay. I have a fe sc trucks but this is my first on road.
It has the hpi vta spec tires on it. This means that its not set up for a 200mm body instead of 190mm correct? And if so will any 200mm body work and look right vta or something new?
Gvm23 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
