Old 07-25-2013, 11:05 AM   #9451
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Tommy R View Post
Definitely go WAY up in front diff oil weight, IMO. I was running either a gear diff with 2.5 million(!) in it or a slipper spool with success. I've run as light as 50k in the front on asphalt and it was fine on a low powered VTA car, but for carpet I ran much higher. Hope this helps!
Oh, another question... Has the car always performed like this on carpet since you built it or has this been a gradual change over time?
First night of racing with it. So it's always been this way
Thanks all for the help. That's a bunch of stuff to try for next week.
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 07-25-2013, 03:54 PM   #9452
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Anyone know what other floater servo arm I can use? With the rsd chassis
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 07-25-2013, 04:05 PM   #9453
Tommy R's Avatar
Trader Rating: 19 (100%+)
Happy to do my part to help! Hope you get it sorted out soon....
Tommy
Tommy R is offline   Reply With Quote
Old 07-25-2013, 04:21 PM   #9454
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by JustWill75 View Post
I have been using YoDog's servo mount on my TC6.1 for a while now with a Futaba BLS551 on it. I was wondering what would happen if spaced the servo forward so that the linnkage between the arm and bellcrank are not swept back as much. I was looking at other steering systems and just noticed that a lot of them place the servo farther forward.
Has anybody esle try this? Is their a benefit to this or not? I'm going to race this Wednesday night and try it out.
It would be a good idea to use the kit servo spacers to move the servo more forward. Depending on the cap height of the servo this will determine how much spacing to use. I'm using the AE 2mm servo spacers with both my Spektrum and Futaba low profile servos.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-25-2013, 04:32 PM   #9455
YoDog's Avatar
Hey George, sorry I couldn't get to you last weekend. Had a ton of wedding issues to work trough then ran really late Saturday morning trying to head up to Reno.
Old 07-25-2013, 05:10 PM   #9456
When will the Tc7 come out ????
bertrandsv87 is offline   Reply With Quote
Old 07-25-2013, 05:30 PM   #9457
CL
CL's Avatar
Trader Rating: 32 (100%+)
2 Weeks...
Believe in yourself!
CL is offline   Reply With Quote
Old 07-25-2013, 06:16 PM   #9458
DARKSIDE's Avatar
really?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 07-25-2013, 06:32 PM   #9459
Mr.juarez's Avatar
no problem rick. i had a bad day anyways out there. good luck with your new job!!
Originally Posted by CL View Post
2 Weeks...
Originally Posted by DARKSIDE View Post
really?
:lo l:
Old 07-25-2013, 09:24 PM   #9460
bhambrent's Avatar
2 Weeks...
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 07-26-2013, 01:16 AM   #9461
Kellen Guthrie's Avatar
So I tried the rick howhart reedy race setup. The only difference is I'm running a front spool with 37.5wt in the rear diff. I'm running 7b and the rear hole for ackerman. Also a regular weight ltr and 32.5 in all 4 shocks. The car is awesome entry to apex but is undriveable out of the corner. I even had barry baker drive it and he couldn't do a lap. Anyone have any idea what might be going on?
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 07-26-2013, 06:35 AM   #9462
Tommy R's Avatar
When I had a similar issue it turns out I had a screw that had backed out of my caster block. Assuming nothing is broken/tweaked, I would again recommend looking into the front droop setting. I hate to sound like a broken record with regard to droop, but I've been amazed at the difference it can make.
Old 07-26-2013, 08:34 AM   #9463
Check the servo saver to see if it has loosened.
MDawson is offline   Reply With Quote
Old 07-26-2013, 09:06 AM   #9464
vivo quevas's Avatar
Trader Rating: 17 (100%+)
I too tried Ricks setup and the car was undriveable! I tried this setup and the car was a lot closer to something I could drive.
http://teamassociated.com/pdf/cars_a..._rroc_2013.pdf
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 07-26-2013, 09:17 AM   #9465
chevtech23's Avatar
+1 on Bobs setup, but be aware you may have to grind on the steering arm to get it to clear the upper deck for clearance. I left mine at 2b.
chevtech23 is online now   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
