Like Tree1Likes
Old 06-30-2013, 10:37 AM   #9331
Default RSD+Yo Dog
Spring tuning set RSD would be partnumer RSD067?
Where to buy the Yo Dog floating servo mount?
Please provide me with a website I can order from.
Thx
Kensei is offline   Reply With Quote
Old 06-30-2013, 02:07 PM   #9332
Default TC6.1W FDR
FDR 3,50 70/40 manual page 29
FDR 4,00 72/36 manual page 29
FDR 4,50 ??/?? which ones to use? not in chart page 29
FDR 4,17 75/36 manual page 29
FDR 4,25(ish) ??/?? which ones to use? not in chart page 29
FDR 4,39(ish) ??/?? which ones to use? not in chart page 29
Which brand of spurs and pinions best to use on the TC6.1?
Where to buy these? (website)
Old 06-30-2013, 02:31 PM   #9333
trigger's Avatar
PRS spurs fit and are really true and narrow. I've also used xray offset spurs too. For 17.5, 92 teeth 64 pitch will do nicely.
To determine gear ratio: spur divided by pinion multiplied by 2.0
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 06-30-2013, 03:39 PM   #9334
i use the narrow rw racing ones, they are made in one tooth increments.
ed
Edwin Pibal is offline   Reply With Quote
Old 06-30-2013, 10:12 PM   #9335
YoDog's Avatar
Trader Rating: 26 (100%+)
Thx
Servo mounts are still pending as I am trying to focus on getting the motor mount prototype finalized. Once I get that done I can spend some quality time in the machine shop to produce all the parts for servo mounts, saver cams and motor mounts.
By the way, the new motor mount will also incorporate an adjustable and removable fan mount!
I'm not gonna post a rendering yet as I don't want to let the cat out of the bag too soon.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-01-2013, 09:05 AM   #9336
Sorry, forgot to mention has to be 48 pitch.
These would fit?
http://www.precisionracingsystems.co...te-Spur-Gears/
and
http://www.precisionracingsystems.co...-Pinion-Gears/
PRS doesn't have the ones mentionend om page 29 of the manual.
The ones PRS has are blanc spaces in the TC6 manual on page 29.
I'm sorry, but I don't understand. Am I missing something here?
FYI the problem is not the calculation. I know how that works.
The problem is finding spurs and pinions that get me the FDR's I want and that are within the TC6 chart as on page 29 of the manual.
Old 07-01-2013, 06:07 PM   #9337
Kellen Guthrie's Avatar
Hey does anyone have a good setup for camarillo? Ill be running a 4.5t motor. Its a medium grip outdoor track with a good amount of bumps.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 07-01-2013, 06:23 PM   #9338
Default Hex Drivers
I bought the Duratrax 19-1 Tool Set but the 2mm hex bit is already stripping my screws so I was looking at the AE Hex Driver Set but it's missing a 2mm hex driver. I know there are other AE kits but why is this when the majority of the AE TC6.1 screws take a 2mm hex driver (I think more than any other size screw)? The 5/64" is technically smaller than 2mm (1.98mm) so wouldn't this strip the screw heads?
I've read good reviews for HUDY hex drivers but I was thinking about getting this set made by BONDHUS which have the ball end. Anyone use these? They are guaranteed for life and made of Protanium which is apparently the strongest kind out there. They also have a ball tip which helps with screwing at an angle.
P.S. Anyone know if a screw remover tool (like a screw extractor bit) would remove a stripped screw on the top plate? I don't think a dremmel tool will work b/c the screw is counter sunk and could cut the top plate.
- Car: Team Associated TC6.1 (Worlds Car)
- Radio: Airtronics MT-4S
- Motor: Thunder Power Z3R-S 21.5T
- ESC: Turnigy Trackstar 80A Turbo Sensored Brushless
- Servo: Savox SC-1251MG
Nickerz is offline   Reply With Quote
Old 07-01-2013, 07:26 PM   #9339
Trader Rating: 23 (100%+)
Ricks asphalt should be good there. See you there in a couple weeks???
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-01-2013, 07:57 PM   #9340
YoDog's Avatar
I would avoid the ball end wrenches as your main tool as they will tend to strip the heads even easier. They are good to have around in a pinch but stick with standard precision ground tips.
Old 07-01-2013, 08:10 PM   #9341
Yeah that's what i figured. Yeah I will for sure be there. I changed my schedule so i have sundays off. Now i'll finally be able to get in some onroad club racing.
LRP America
Old 07-01-2013, 08:43 PM   #9342
Thanks Rick! Which brand hex do you use? Does it make sense why AE doesn't have 2mm hex driver btw
Lovin' your servo mount and look forward to your motor mount!
Old 07-01-2013, 09:21 PM   #9343
fresnojay's Avatar
Hey Nick, I personally have used nothing but Dynamite brand hex driver and had no issues with them at all. I used them on your TC6.1 as well as my new TC6.1. They are strong and in 3+ years of using them haven't broken 1 of them. The only screws I stripped were ones that for whatever reason I didn't get the driver seated fully in the head.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 07-01-2013, 10:42 PM   #9344
Trader Rating: 38 (100%+)
Hey guys I recently got a worlds roller and I need to get the spur/pulley assembly out. What is the easiest way with least amount of disassembly to do so? TIA!
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 07-01-2013, 10:52 PM   #9345
trigger's Avatar
^^^^the top deck will need to come off, then just undo the two little screws holding the spur in place. Viola, off comes the layshaft.
Minh Nguyen
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
