Like Tree1Likes
Old 06-14-2013, 02:49 PM   #9301
Originally Posted by rbarciko View Post
I can no longer find the original website, so I can't take the credit for these, but these tables show what spurs and pinions fit in a TC6 for 48 and 64 pitch:
http://deckjockey.com/tc6/wp-content.../08/gear64.png
http://deckjockey.com/tc6/wp-content.../08/gear48.png
GOOD!!!!
http://abram.eu.org/gear_tc6.php for tc6/tc6.1/tc6.1.we
and for older TC5
http://abram.eu.org/gear.php
Michal Abramowicz
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-14-2013, 02:59 PM   #9302
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by DesertRat View Post
I could never really tell the difference in car performance when I change the shock angle. What differences should I see on stood-up vs lay-down on lay-down on the tower because accounts differ... does standing up the front shock give you more turn-in and sstanding up the rear gives more rear bite? I've never really gotten a hold of this...
I've been spending some time with this myself. Usually many of us can't tell much difference when changing a particular setting because the baseline setup is so out of whack that a change in something could yield opposite results or none at all. I've had people poopoo suggestions that I make because they say they "already tried it and hate it". After looking more closely to their car, you begin to realize that there are some fundamental problems with the chassis to begin with. No wonder the change didn't work as expected.
So anyhoo... laying the shocks down will make them more "progressive" meaning that they will initially compress easily and get stiffer as they compress further. This will act like a soft setup under small changes in weight transfer and stiff with larger changes in weight transfer. This goes for front to rear as well as side to side. On a properly setup car, this can increase grip at initial movement. Shocks standing more upright is more linear and reacts quicker. So as the weight is transferred, the car feels more "live".
Now, if the chassis is poorly setup or too flexible, these changes will be less obvious and are not likely to fix the problem you may be having.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 06-14-2013, 03:34 PM   #9303
DesertRat's Avatar
I haven't had many problems with the car lately, it runs good but it seeme numb to changes in shock angle as long as I reset the droop/ride height correctly. Maybe it's because I adjust my steering dual-rate to compensate for a loose or pushing car.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 06-16-2013, 10:03 PM   #9304
fresnojay's Avatar
Signing on as I AGAIN own a 6.1 Worlds and am now more active on these forums.
Rick, That motor mount looks killer! Put me on the list for one. Also I need to get another floater arm from you for the new car and maybe that servo piece you were working on if you have them ready now.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 06-16-2013, 10:03 PM   #9305
fresnojay's Avatar
Rick, That motor mount looks killer! Put me on the list for one. Also I need to get another floater arm from you for the new car and maybe that servo saver piece you were working on if you have them ready now.
Jason
Old 06-17-2013, 12:33 AM   #9306
Kellen Guthrie's Avatar
Hello,
I was curious as to what hop ups are essential for this car. Has anyone tried the rsd chassis and bellcranks? And what is a good setup to start with? I will be running mod touring car on high bite asphalt.
Thanks,
Kellen
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 06-17-2013, 08:37 AM   #9307
Rick Hohwart's Avatar
Originally Posted by Kellen Guthrie View Post
Hello,
Thanks,
Kellen
In my opinion the must-haves are:
RSD DCJ drive shafts w/hex.
RSD tuning spring set.
AE gear diff (for front).
You may or may not use the gear diff but it is a nice thing to have on hand for tuning. And if you use the gear diff you probably won't need the DCJ drive shafts.
Some other nice items that are good to have but not required:
Yodog floating servo mount.
RSD soft shock bladders.
AE aluminum screw kit.
Modifications that I recommend:
Drill a 1.5mm hole in each shock cap.
Grind the left front bulkhead and top deck so that you can get full L/R steering throw when using the forward steering post hole.
You don't need much to make the car very good so don't worry about spending a lot of money when you don't have to.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 06-17-2013, 08:59 AM   #9308
Alright thanks I will order those. I was just looking at the rsd chassis so I could run dual bellcranks instead.
LRP America
Old 06-17-2013, 09:10 AM   #9309
patorz31's Avatar
Rick to you have a pic of the mod you mention?
patorz31 is offline   Reply With Quote
Old 06-17-2013, 09:58 AM   #9310
Hard to see but you can see where the bulkhead and the steering rack has been ground down. Plus the top deck is ground as well.
If you use the floating servo mount, you can remove the steering arm and it will not interfere.
www.reedypower.com
Old 06-17-2013, 10:18 AM   #9311
patorz31's Avatar
Thanks Rick.
Old 06-17-2013, 11:30 AM   #9312
YoDog's Avatar
Thanks for the recommendation, Rick!
The new motor mount and racing has been taking up a bit of my time lately but I can see that another run of servo mounts is in order.
Old 06-17-2013, 11:33 AM   #9313
YoDog's Avatar
Jason
Hey Jason, come and see me at the track next Saturday. I'm all sold out at the moment but will be making more parts real soon.
Old 06-17-2013, 07:37 PM   #9314
fresnojay's Avatar
Kellen, Like others have said the car can use some odds and ends but they are not too expensive. I don't have any of them at the moment and the car is running well even in its untuned state.
Rick, Will do. Can't wait to get her back out to the track for some tuning. I have got some more speed in her now. So we shall see how she does in that department.
Jason
Old 06-18-2013, 04:46 AM   #9315
ark
Hi Rick, do you run 3mm spacer under the ball link.? (in photo)
ark is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
