Like Tree1Likes
Old 05-01-2013, 10:25 AM   #9136
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Originally Posted by Tommy R View Post
Generally speaking, does introducing more chassis flex to gain traction on a slippery service benefit the front or rear moreso than the other? Or does it add traction equally front and rear?
With alot of time testing on asphalt, I found using o-ring under screw head modification provided more traction for the rear of the car when making the changes to the rear of the upper chassis plate. More traction was gained in the front when making the modification to the front of the upper chassis plate. I had best results and feel when I used the o-ring modification under all upper screws (leaving the 2 closest screws to the front bulkhead in stock configuration). Maybe worth a try if your on a low to mid traction asphalt track, hope this is helpfull.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 05-01-2013, 10:31 AM   #9137
Team Grid RC's Avatar
Great idea but you need to first allow the heaviest components that is bolted or strapped to the chassis to float so once you use the o-ring method, the chassis will really flex and twist. The Lipo and servo can affect the handling since the area below it can not flex freely.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 05-05-2013, 09:05 PM   #9138
95lscoupe's Avatar
For anybody with the RSD lowerd shock conversion how do you like it on asphalt any improvement? from the pictures it looks like there isnt much shock travel left. Thanks
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 05-06-2013, 06:59 AM   #9139
Rockin G's Avatar
I saw Cristian running his one day. He showed it to me and there was still plenty of travel. It was dialed.
Rockin G is offline   Reply With Quote
Old 05-06-2013, 11:33 AM   #9140
ekim628's Avatar
The RSD LCG springs and towers dont really make a huge difference in my opinion. I have tried testing back to back and lap times are the same. The lowered shock tower and the smaller springs make the car feel flat versus the stock setup.
As you see in the picture there is a good 10mm of shock travel. It takes a bit of work to get the most travel with these smaller springs. I had to cut the lower shock cups on the thread side about 2mm and this lowered the lower spring cups. This way i can get more travel and get the most vertical movement from the shaft. I feel there is not enough pack in the shocks since the piston sits so high in the shock chamber, thus the flat feel of the car when using this setup.
I believe the stock setup is the way to go until we can get a true short shock setup from Associated or RSD. Christian did an awesome job with this upgrade, now we just need the shocks to match
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 05-06-2013, 12:04 PM   #9141
95lscoupe's Avatar
Thanks for the imput. I was worried about how the shocks would react riding so compressed. Hmm decisions decisions.
Matthew Abey
Old 05-08-2013, 01:08 PM   #9142
Crashmaster's Avatar
Hi guys,
After a bit of setup advice! I'm running 17.5 blinky with the following setup:
http://www.petitrc.com/reglages/asso...2011111920.pdf
The car feels pretty good but I could do with a stronger front end on initial turn in, generally off power but also in some neutral power corners - basically after more corner speed!
I'm thinking of trying the following things, any advice/ guidance you can give would be greatly appreciated
- Increased rear droop - more weight transfer?
- More shims on front link outboard for more camber gain
- Drop rear toe in to 2.5deg
- Stiffer rear anti roll bar
- Removed front arm sweep to gain more entry steering?
I'm just learning with setup so not sure if the above things are logical things to try. Any guidance you can give would be appreciated.
Dan
Crashmaster is offline   Reply With Quote
Old 05-08-2013, 05:06 PM   #9143
YoDog's Avatar
Trader Rating: 26 (100%+)
Default R-Factor RC
It's official Ya"ll!
The first branded batch of servo mounts and savers are headed to Australia!
Thanks to all of you who purchased my stuff. You have made it possible for me to be able to reinvest into my endeavor and make it grow into something legit. I will be expanding my parts selection and launching a website in the not too distant future as well.
The company is now called "R-Factor RC" and the website will be at:
www.r-factorrc.com when the site is finally launched.
Thank you all for your support!
Here is a pic of what the new packaging and logo will look like.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 05-08-2013, 06:25 PM   #9144
Trader Rating: 312 (100%+)
Any pics of your products installed and price?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-08-2013, 07:47 PM   #9145
BillPear's Avatar
Send a message via Yahoo to BillPear
What more can I say except CONGADULATIONS!, and GOOD LUCK!
BillPear is offline   Reply With Quote
Old 05-08-2013, 08:23 PM   #9146
YoDog's Avatar
Here are some from a little while back.
Need to take more soon.
The mount is a direct fit for all TC6.x chassis, no drilling.
Price is $20 shipped in the U.S.
All of the last batch is headed to Australia but I do have a few of the older version left that I can sell @ $17.00 each if you are in a rush.
Team Associated TC6 Thread-20130321_145746comp.jpg   Team Associated TC6 Thread-20130305_200358-comp.jpg
Old 05-09-2013, 05:44 AM   #9147
Originally Posted by Crashmaster View Post
Hi guys,
Dan
Although I'm no expert, from my experience I would try to raise the rear roll center (0b mounts). Also I think you are running some strange shock positions, I think you should look to other setups for some ideas.
z3zinho is offline   Reply With Quote
Old 05-09-2013, 06:59 AM   #9148
Rick Hohwart's Avatar
Good luck - stuff is DIALED!
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 05-09-2013, 09:24 AM   #9149
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Rick Hohwart,
Have you used the short shock conversion on your TC yet?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 05-09-2013, 09:43 AM   #9150
Originally Posted by ChadB. View Post
Rick Hohwart,
I have not. I pretty much run my car stock except for RSD driveshafts and shock bladders.
www.reedypower.com
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
