Old 12-07-2010, 01:23 PM   #901
Murray is offline   Reply With Quote
Old 12-07-2010, 01:30 PM   #902
Johnny Wishbone's Avatar
Default ? for you Keven
I know this is the wrong forum, but which speed control where you running at the Cleveland race for the 17.5 boosted class, with what software, if you know?
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-07-2010, 01:49 PM   #903
Buckaroo's Avatar
Originally Posted by Keven H View Post
Yes it the ball height ! the Silver is 0.030 taller
Since the car is all metric, that equates to about .76mm
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-07-2010, 02:56 PM   #904
xray09ACT's Avatar
As for the spring, Green is softer than silver. If I am not mistaken green is 11 and silver is 14.
Hope this helps
erm yup your right, maybe i hadn't had enough coffee when i wrote this
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 12-07-2010, 08:04 PM   #905
jhock's Avatar
Who sells the gear diffs for the TC6? In the states, I tried the one I have for the Top but doesnt work, been lookiin for other brands. Anyone have pics of them installed? Also, Do you need to buy a specific pulley for the gear diff or you can use the ones in kit?
Team Driver Schumacher USA
SVR
SX3
Tekin
KO Propo
jhock is offline   Reply With Quote
Old 12-07-2010, 08:29 PM   #906
xray09ACT's Avatar
Yokomo bd-5 gear diff
top photon, apparently needs adjusting
Spec-r diff for yokomo
probably best if you went back a couple of pages as everything is detailed there.
Old 12-07-2010, 08:53 PM   #907
jhock's Avatar
X-ray, you hAve part numbers for the doffs and who sells them?
SVR
SX3
Tekin
KO Propo
Old 12-07-2010, 09:02 PM   #908
A Ilievski's Avatar
Trader Rating: 39 (100%+)
The best of the 3 is the Yokomo Bd5 gear diff.
Part number is YOK-BD-500GS
As for whats needed to make it work read back about 8 pages its all there.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 12-08-2010, 03:04 PM   #909
i1justin's Avatar
Trader Rating: 20 (100%+)
his setup sheet from the indoor champs is posted http://www.teamassociated.com/pdf/ca...hamps_2010.PDF Lists him using the the SXX stock spec software 4.0
Justin Wilde
AE - Reedy - JConcepts - Airtronics
Irony- Racing Nitro requires more Batteries than Racing Electric.
www.NCTracing.com
i1justin is offline   Reply With Quote
Old 12-08-2010, 03:37 PM   #910
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-08-2010, 05:30 PM   #911
i1justin's Avatar
and just to verify, I know its been said on this thread the kit comes with hard parts, so are we saying just about every plastic suspension component part # listed in the manual is incorrect then for ordering the correct replacements
Justin Wilde
www.NCTracing.com
Old 12-08-2010, 05:41 PM   #912
pcar951's Avatar
Trader Rating: 19 (100%+)
Default TC6 Wow
Ran my 6 last night for the first time...Wow, great corner speed, very predictable drive. A couple of things that we all may have to watch for, or have already found out:
- suspension mount screws came lose on about the 5th run (I shoulda checked them)
- servo saver nut backed off (shoulda checked it too)
I'll be getting out the loctite but, so far great car!
pcar951 is offline   Reply With Quote
Old 12-08-2010, 10:51 PM   #913
tqcookie's Avatar
Hey guys, just getting the TC6 all buttoned up for this weekends race and have a couple of questions. I am putting Kevin Hebert's Timezone setup on the car and the setup sheet says 3* total toe for the rear. Does this equate to 1.5* per side. Also when refering to arm mount shims, the book says we should have 1mm, 1.5mm and 2mm shims. However, when measured with a calipper none of the shims are actually as thick as they are supposed to be. So on Kevin's setup if it calls for 3.5mm arm mount shims, do you think he is using what is supposed to be 3.5mm from the kit, or another shim that actually totals 3.5mm?
tqcookie is offline   Reply With Quote
Old 12-08-2010, 10:59 PM   #914
Trader Rating: 2 (67%+)
is the TC6 any better than the TC5 on carpet racing?
Losidriver304 is offline   Reply With Quote
Old 12-08-2010, 11:09 PM   #915
ed517's Avatar
I picked up .2 sec a lap on my first test day with it. It did help having AE team driver Lex Tyler helping me with set up(thanks for da help,you the man) the car is much better with weight transfer esp on our small track.
ed517 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
