Like Tree1Likes
Old 04-24-2013, 06:13 AM   #9121
Originally Posted by J_Bone View Post
Next question:
Has anyone had issues with the o-ring in the shocks being squished to tight? Mine do and I had to sand down the o-ring spacer. They were 3.92mm thick and I sand mine down to 3.6mm and it seems to be perfect. No more binding.
I've had that problem with one set of shock. Solved it by sanding down the "shaft guide"/o-ring spacer and switched to RSD o-ring which seems to be softer.
z3zinho is offline   Reply With Quote
Old 04-26-2013, 10:22 PM   #9122
DesertRat's Avatar
Well, I think this car is finally right. I stripped it to pieces to un-tweak the chassis, and when I was done it sat perfect on my tweak board and with the scales at all four corners the readings were less than a gram off. I hope that means traction, because this thing owes me some.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is online now   Reply With Quote
Old 04-27-2013, 06:41 AM   #9123
kewdawg's Avatar
So, what was causing the tweak?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-27-2013, 06:55 PM   #9124
DesertRat's Avatar
When I assembled the car, the front tab of the motor mount which anchors to the chassis tweaked the chassis plate... that was the worst of the problems. I ran it today and it was more promising, but the track traction was too low to really get it going.
Old 04-27-2013, 08:34 PM   #9125
I plan on running in the GT3 class and have a 21.5T brushless motor. Can anyone recommend a good Spur & Pinion combo?
Btw, my car weighs just under 3lbs. (2lbs, 9.7oz).
Thx
Nickerz is offline   Reply With Quote
Old 04-29-2013, 02:11 PM   #9126
go back a few pages i think i read a fix where you place a 1mm washer under that end and helps take out the tweak
hope this helps
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 04-29-2013, 04:09 PM   #9127
CristianTabush's Avatar
NEW Bumper!
RSD101 RSD AE TC6/TC6.1 Hard Wide Front Bumper
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-29-2013, 04:23 PM   #9128
DesertRat's Avatar
hope this helps
yeah that was me complaining about it before... I just leave the L-shaped bracket off and let the motor mount float. What helped since then was a teardown and rebuild with a different suspension setup, I still have work to do as the car has too much dive when I jam the brakes, maybe I'll try some anti-dive on the front.
Old 04-29-2013, 05:48 PM   #9129
Bibie's Avatar
Hey what are the options to get more steering on the tc6??
Bibie is offline   Reply With Quote
Old 04-29-2013, 07:23 PM   #9130
Team Grid RC's Avatar
Move your battery forward and float it. Also float the servo so the front chassis will flex more naturally. You should notice a difference without any other changes.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 04-29-2013, 08:08 PM   #9131
Bibie's Avatar
Thanks will try it!!
Old 04-30-2013, 06:04 AM   #9132
Redwood's Avatar
Hey guys,
Since most of the new setups coming out from the team use the new vertical ballstud camber links, and I have the old TC6 style, shock tower links, does anyone have some kind of comparison between the different settings? i.e. if the setup calls for V3 setting with 2mm shims, is there an easy way to tell which setting would be closest to that for the old shock tower mounting?
Cheers,
Neal
Redwood is offline   Reply With Quote
Old 04-30-2013, 07:56 AM   #9133
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
You can also experiment with the removal of upper chassis deck screws (by opossing pairs) or use o-rings under screw heads to allow more flex and gain additional traction while cornering.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 04-30-2013, 08:41 AM   #9134
Can you post your setup? You don't specify if it's corner entry/mid/exit, and on/off power, so I would assume that you are having trouble getting the car to rotate. I would try to raise the rollcenter in the rear. So if you are using 0B lower arm mounts all around, try 1B in the rear.
Old 04-30-2013, 08:49 AM   #9135
Tommy R's Avatar
Trader Rating: 20 (100%+)
Generally speaking, does introducing more chassis flex to gain traction on a slippery service benefit the front or rear moreso than the other? Or does it add traction equally front and rear?
Tommy R is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
