Like Tree1Likes
Old 03-19-2013, 07:47 AM   #8986
JustWill75's Avatar
Send a message via AIM to JustWill75
I would like to see the answer to this one as well.........
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is online now   Reply With Quote
Old 03-19-2013, 08:02 AM   #8987
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I'm no engineer but I did stay at a holiday inn. To me it has a more direct feel to the steering. I don't know if it is real or imagenary.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 03-19-2013, 08:10 AM   #8988
wtcc's Avatar
I felt no difference in steering at all.
Positive is the space you have for the receiver, etc. and that you are able to equal the front tire load by moving weight on the motor side to the front (equalling the battery).
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 03-19-2013, 09:14 AM   #8989
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Tommy R View Post
I've been searching, but haven't quite found what I'm looking for. What are the benefits to mounting the servo sideways? Is the real benefit that the servo is away from the chassis and, therefore, not restricting the chassis from flexing? Are there other benefits I'm missing? Can someone provide a brief explanation? I'm intrigued at the concept, but am not one to just go buy parts unless I understand the principle behind them.
Thanks!!
Hi Tommy,
there is actually a discussion on rctech regarding this topic. It's my understanding that since there is only one servo mounted on one side of the chassis, there is unequal flex at the front of the chassis as long as the servo is part of the chassis structure. The "floating" principal is a little misleading as the servo doesn't need to be lifted from the chassis plate or "floating", the more realistic term should be "single point mounting" or "central point mounting". There are a few benefits of using this type of mounting configuration.
1) Turning the servo 90* will move the weight of the servo more forward in the chassis to help with offsetting the motor weight (if on the same side of the chassis).
2) More room for the electronics and freedom to dictate their location better.
3) A single center line mounting point for the servo which helps to remove rigidity bias toward one side of the chassis by eliminating the servo as a structural member.
I've heard many alternatives to achieving this effect but most of them involve servo tape or Shoo Goo. These solutions are not likely to be reliable and still create some structural bias on the side that the servo resides.
It seems these days it's all about controlling chassis flex and reducing the influence of other components on it. The more flexible the chassis, the more other factors will have influence over said flexibility.
I hope this helps...
YoDog is offline   Reply With Quote
Old 03-19-2013, 10:00 AM   #8990
Tommy R's Avatar
Trader Rating: 19 (100%+)
Thanks, YoDog! Yes, that helps very much and hits on the topics I was thinking would be most relevant. Tell me this. I can certainly understand wanting to eliminate the servo (or other components) from adversely affecting the rigidity of the chassis. But what about the battery on the other side? Is that not as big a factor because it's not physically fastened down? I would imagine tape or straps don't provide near the same structural integrity. Or do manufacturers consider then when they design the chassis?
Regardless, expect a PM from me soon.
Tommy R is offline   Reply With Quote
Old 03-19-2013, 10:02 AM   #8991
bertottius's Avatar
The battery does stiffen the chassis. A simple fix is to put a couple strips of battery tape under the battery so as to create a gap between the battery and the chassis. It doesn't take much and it does the trick.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is online now   Reply With Quote
Old 03-19-2013, 10:03 AM   #8992
bertottius's Avatar
Is that what you mean?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 03-19-2013, 10:19 AM   #8993
YoDog's Avatar
This is what I do. I actually provided some thin foam strips with the very first batch of the servo mounts.
The battery, when taped down still allows the chassis to twist without too much restriction since it is not actually bonded to the chassis in some way.
Old 03-19-2013, 10:32 AM   #8994
Tommy R's Avatar
Yep, that was my concern. So are y'all saying to put a couple strips of tape under the front and rear of the battery to ever so slightly elevate it off the chassis? Or do orientate the tape another way?
Old 03-19-2013, 10:46 AM   #8995
Rockin G's Avatar
Tommy, next time you're out there, come by my pits. I'll show ya.
Rockin G is offline   Reply With Quote
Old 03-19-2013, 10:50 AM   #8996
Tommy R's Avatar
So you've been hiding this secret from me all this time while I'm struggling to keep up with Jimmy??
Old 03-19-2013, 12:08 PM   #8997
YoDog's Avatar
Here is a pic of my arrangement.
Old 03-19-2013, 12:14 PM   #8998
Tommy R's Avatar
Thanks, Rick! Do you use a couple thicknesses of tape or is one sufficient?
Old 03-19-2013, 12:23 PM   #8999
Trader Rating: 309 (100%+)
Where can you get that vertical servo holder?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 03-19-2013, 12:26 PM   #9000
I put three layers of tape in the middle and that does the trick.
SANCHA is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
