Like Tree1Likes
Old 03-01-2013, 06:02 PM   #8866
BillPear's Avatar
Send a message via Yahoo to BillPear
Is it possible to fit a 64P 84 tooth spur to get a FDR down around 3.0 in this ride?
BillPear is offline   Reply With Quote
Old 03-02-2013, 09:58 AM   #8867
With roughly a stock setup do which arm mounts do I need to change to 3A and what other setting do I have to change?
As for the poster above me the site for all possible gear ratios you can fit in the car the site is on page 575 of this thread.
Night is offline   Reply With Quote
Old 03-02-2013, 11:50 AM   #8868
Yes.
bmannokc is offline   Reply With Quote
Old 03-02-2013, 12:45 PM   #8869
BillPear's Avatar
Originally Posted by bmannokc View Post
Yes.
Thank You.
Old 03-02-2013, 01:39 PM   #8870
KC10Chief's Avatar
Get a 64P 56T pinion and you'll have a 3.00 FDR. Check out this website.
http://abram.eu.org/gear_tc6.php
AE TC6.1 WC w/RDS 6.2 Chassis; AE TC4
AE RC8T w/Tekno V4 electric conversion
2ea SC10; 2ea Losi Mini 8ight
TLR Ten-SCTE 2.0 (On Order)
KC10Chief is offline   Reply With Quote
Old 03-03-2013, 10:52 PM   #8871
adriang79's Avatar
Im running a TC6.1FT and would like to try out one of the latest setups sheets. I am still running the shock tower mounted upper links and obviously all the latest setup sheets are for the vertical upper,link mounts.
I was wondering what holes in the tower the vertical holes match up to?
www.stmcc-hobart.weebly.com STMCC Secretary
Team Associated TC7 - Hobbywing V3.1 Stock spec -Team Powers Actinium 13.5
http://stmcc-hobart.weebly.com/rcmaker-tas-challenge.html
adriang79 is offline   Reply With Quote
Old 03-04-2013, 02:37 PM   #8872
Jscott54's Avatar
Here is my TC6.1
Josh Scott
FTW-For The Win RC Bodies, Paint by RJ, Venom Batteries, Atomik Rc, Mr.Sign Graphics, Agama, Hobby-Pro USA, Beta tires
Jscott54 is offline   Reply With Quote
Old 03-04-2013, 03:00 PM   #8873
Originally Posted by Jscott54 View Post
Here is my TC6.1
Looks good but two things steering blocks are upside down and I would suggest you make the one battery lead shorter so u can't accidentally reverse them.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-05-2013, 07:38 AM   #8874
Jscott54's Avatar
We run (me and everyone else that runs the TC6) the steering blocks upside down on our asphalt track, it is not as agressive as standard.
When it is pluged in to the battery it is the perfect length.
Josh Scott
Old 03-05-2013, 08:44 AM   #8875
Cool looks good.
Old 03-05-2013, 08:46 AM   #8876
turbodog's Avatar
I am going to guess that caster blocks are not set correctly either. they look straight up or negative.
Troy Schafer
turbodog is online now   Reply With Quote
Old 03-05-2013, 03:29 PM   #8877
YoDog's Avatar
Trader Rating: 26 (100%+)
Hey Guys, just following up... How's the servo mounts working out for those of you who bought them from me? Any questions or suggestions?
I will have the V2 model coming very soon! I will post pics as soon as the blocks are tapped.
YoDog is online now   Reply With Quote
Old 03-05-2013, 04:02 PM   #8878
durtbag's Avatar
Thumbs up YoDog Servo Mount
Definitely a nice bit of kit! Just installed in my VTA, buyers will need a longer turnbuckle or longer ball ends. No biggie. Fit and finish is really good, supplied hardware is a bonus.
I have purchased other products from large companies that were of far less quality. I look forward to trying it out this weekend
Thanks, for the great service, Terry
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 03-05-2013, 04:27 PM   #8879
JustWill75's Avatar
Send a message via AIM to JustWill75
Wow that thing looks so factory. I wonder if Team Associated has been trying this stuff out? I'm going to wait for your version 2 pics. I may have to get on of these jammyz.......
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 03-05-2013, 06:02 PM   #8880
YoDog's Avatar
Nice install Terry!
I could have sworn that the stock turnbuckle was long enough. Now that I've looked at my car again, I used one longer ball end which made up the difference. Last weekend I installed one of those infamous Savox standard sized servos which on most floaters will hit the steering assembly. It fit perfectly!!! Initially I took a guess based on the published dimensions and now it's confirmed.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
