Old 02-25-2013, 11:09 PM   #8851
hanzo3's Avatar
Trader Rating: 55 (100%+)
I built a new worlds edition 6.1. Trying to get a 5mm ride height and to get this my shock collars are all the way up. I am using tamiya hard springs. What did I do wrong?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-26-2013, 12:02 AM   #8852
Francis M.'s Avatar
Are you using the inside hole on the arms?
Francis M. is offline   Reply With Quote
Old 02-26-2013, 12:11 AM   #8853
hanzo3's Avatar
Nope. I need to add some arm mount shims I guess.
Chris TRF419 TA05V2
Old 02-26-2013, 09:31 AM   #8854
YoDog's Avatar
Trader Rating: 25 (100%+)
Well, you are using hard springs which probably don't compress much under the weight of the car. The springs you are using are probably slightly longer as well. Get yourself some shorter springs in the harder range if that is how stiff you want to run your car to compensate for the reduced compression. Shorter ball cup shock ends can help as well.
YoDog is offline   Reply With Quote
Old 02-26-2013, 01:44 PM   #8855
20967's Avatar
Originally Posted by 20967 View Post
I have a question about Arm Mount. I noticed a lot of gap in the Arm Mount hole where the hinge pin is insert in them, this also after fews race.
This gap is more or less higher and different for each supply where I buy.
Is normal or not?
The "PPD Billet" is good, but do not have the choice of new offset and not easy to set up.
Any help is appreciated
Any help for me?
Enrico
20967 is offline   Reply With Quote
Old 02-26-2013, 01:46 PM   #8856
Any help for me?
Enrico
have you tired the newer tc6.1 offset mounts ? they are much better that the tc6 mounts
Ed
Edwin Pibal is offline   Reply With Quote
Old 02-26-2013, 02:56 PM   #8857
wtcc's Avatar
The new mount are not better than the old ones if we just look at the "gap".
I do not understand the problem with the PPD billet mounts. They work very good (no gap) and already come with offset like the new TC6.1 armmounts. If you need more offset you need shims, but that is the same thing with the original armmounts.
Only the height of the suspensionarm has to be checked if you change it with the thumbsrews of the PPDbillet armmounts, but therefore you do not have to change them all around which saves a lot of time. I for myself do not change the height often, as there are other setup options that are a lot more effective.
As an alternative to the PPDbillet you can try the ReflexRacing...oops I just saw they don't offer that part anymore... So there is no alternative other than the (expensive) Exotek conversation to suspensionblocks.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 02-26-2013, 10:20 PM   #8858
Verndog's Avatar
Trader Rating: 16 (100%+)
Any help for me?
Enrico
I can help. Dial-a-Grips... and problem solved...for good!
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-27-2013, 02:58 AM   #8859
That's perfect. I like this much.
vilashraj00 is offline   Reply With Quote
Old 02-27-2013, 03:26 AM   #8860
bertottius's Avatar
Originally Posted by BillPear View Post
I try to avoid setup questions in these forums since I dont drive like you nor you me and we probably arent at the same track, but I do have one general one. I am setting up my TC6.1FT for VTA, that said I had to add 130g of weight to bring it up to the 1550g minimum, Can you guys suggest a good place to start with the springs? I cant imagine the original silver ones are quite enough for the extra weight.
Thanks.
I run the stock silver springs and they are just fine.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 02-27-2013, 12:47 PM   #8861
Rick Hohwart's Avatar
Default New setup posted
Keven Hebert - 2013 Snowbird Nationals
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 02-27-2013, 06:19 PM   #8862
BillPear's Avatar
Send a message via Yahoo to BillPear
Thanks, even with all the extra weight?
BillPear is offline   Reply With Quote
Old 02-27-2013, 06:57 PM   #8863
RaceAce701's Avatar
Trader Rating: 83 (99%+)
yep they will be fine i use them on my vta car with no issues some chassis scrub in fine
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 02-27-2013, 08:25 PM   #8864
BillPear's Avatar
Thank you, very much.
Old 02-28-2013, 05:46 AM   #8865
20967's Avatar
Thks guys much appreciated.
Enrico
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
