Like Tree1Likes
Old 02-24-2013, 03:32 PM   #8836
Monsta's Avatar
Thought I'd report back with my result's from two pages back re excess front grip/loose neutral issues
I had returned the setup back to stock ie; camber, springs etc which helped a bit.
At next the race day, another drivers suggested more droop f& r and more ride height. Went to 4mm f and 5mm r droop and raised it to 6mm ride height.
This has fixed the loose neutral power issue completely
Thanks for everyones suggestions!
Originally Posted by Monsta View Post
I have recently done the Exotek Duel Bellcrank conversion. I now have a huge amount of front end grip.
Unfortunately the car is now excessively Loose Neutral Power, will do a 180 no problem. I have tried softening the rear, stiffening the front (including swaybars), rasing and lowering droop on both ends, lighter oil in the rear gear diff (spool front), lowering roll centre rear – raising the front, rasing the front high and lowering the rear.
Im using sweep 32s on med grip outdoor asphalt
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 02-24-2013, 03:57 PM   #8837
LEM C's Avatar
Originally Posted by RaceAce701 View Post
ok a few questions for everyone
rear diff oil wt
light vs heavy and the affects on handeling
i tried several different setup approaches and am just looking for a few things to try to more or less remove front traction (i had to cut my dualrate in half just to jeep the car on the track)
For me 40wt works well indoor and out. When traction is high the rear end doesn't rotate well so going with a heavier oil should loosen the rear up a bit.
Widening the front end with spacers between the bulkhead and arm mounts helps out. For quick fix glue your front sidewalls 3/4 up and try less sauce in the front.
RC Cars-Lipos-ESC-Brushless Motors-Surface Radio-Carpet Track-Asphalt Track
LEM C is offline   Reply With Quote
Old 02-24-2013, 05:16 PM   #8838
rcwck's Avatar
Originally Posted by jmike View Post
I just have to vent, i was leading the amain tonight when one bump with some traffic ended up breaking my front a-arm. I love how my car drives but this is the third week in a row a front end part has broken and cost me my main event finish. I'm a pretty clean driver and don't make too much contact out there. I'd hate to say it but it makes me feel like selling and trying someing else.. Too bad, the car is fast as hell.
Some racers around here make a 1/8th" thick Kydex front bumper wide enough to help protect the front suspension parts. It comes in 8" x 12" sheets for about $20. It helps lots. I race a TC6.1W and the new Serpent411 ERYX. The Serpent seems way more crash resistant.
rcwck is offline   Reply With Quote
Old 02-24-2013, 06:41 PM   #8839
The other thing I wanted to tell u was to try taking the sway bars off.
in the main i ran 4wt all around losi 56 pistons rsd yellow in front and teal in rear and that was the best the car was all day
i did try ae silver front ae green rear and that car was good also but still tippy mid to late corner
i started with yokomo blue front and pink rear and it was good when bite was los but as soon as it came up it was impossable to exit the corner without any speed at all
i played with rear track with as perr cuffs advice and wider was better i went from narrow arm mouts and 1mm hex shim (what cuffs ran ) to no hex spacer and plus 1.5 each side on the arm mounts and was a bit better
i ran 3b roll center all around i was thing about trying ob in the front
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-24-2013, 07:16 PM   #8840
RaceAce701's Avatar
Trader Rating: 84 (99%+)
the guy i borrowd the spring off of mentioned that as well that will be one of the first things to try next time it gets tippy
i tried so many things yesterday im still trying to sort out what worked and wat didnt the one thing that i know seemed to help was laying down the shocks 1 hole front and rear made a noticable difference i just wish i tried it earlier in the day
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 02-25-2013, 04:08 AM   #8841
kewdawg's Avatar
Not sure what the Losi 56 pistons have as far as hole diameter. I'm using the TC6 #2 pistons up front and #3 in n the rear. Try 50wt. oil up front with 15.5 lb. springs. The heavier oil should tone the front end down.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-25-2013, 06:02 AM   #8842
Tommy R's Avatar
Trader Rating: 20 (100%+)
Hey folks,
I bought my TC6 used and it had some double cardan joint front axles already installed. Well, I broke one this past weekend. The problem is I'm not sure what kind they are. I seem to recall being told they were made by Hot Bodies, but I'm not positive. I'm trying to get in touch with the original owner of the car to confirm, but need to get parts ordered ASAP in order to make the race this coming weekend.
I realize it's a shot in the dark, but could anyone identify this axle? As far as I can tell, there's no distinguishing lettering or markings on it.
If it can't be identified, I'd appreciate if anyone could suggest some good replacement DCJ axles. This isn't used in a very powerful car (USGT) if that makes any difference?
Thanks!
Tommy R is offline   Reply With Quote
Old 02-25-2013, 08:45 AM   #8843
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Tommy R View Post
Hey folks,
I bought my TC6 used and it had some double cardan joint front axles already installed. Well, I broke one this past weekend. The problem is I'm not sure what kind they are. I seem to recall being told they were made by Hot Bodies, but I'm not positive. I'm trying to get in touch witnh the original owner of the car to confirm, but need to get parts ordered ASAP in order to make the race this coming weekend.
Thanks!
your dcj doesn't look broken it looks like the pin fell out or broke!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 02-25-2013, 09:10 AM   #8844
Rockin G's Avatar
Tommy, I have never had one, but I know Reflex (Cristian) sells DCJ's. Not sure if that is his or not, but he would be able to tell ya.
Rockin G is offline   Reply With Quote
Old 02-25-2013, 09:21 AM   #8845
Francis M.'s Avatar
Hey folks,
Thanks!
That looks to be the original HB DCJs. They're one and done (non rebuildable)
Look into the TAMIYA DCJs. these have been the most durable DCJ i've used to date.
Francis M. is offline   Reply With Quote
Old 02-25-2013, 09:51 AM   #8846
kewdawg's Avatar
Hey folks,
Thanks!
Go with the Reflex Racing units. Really good stuff.
Quinn Moon
Old 02-25-2013, 09:58 AM   #8847
Tommy R's Avatar
Thanks, fellas. Yeah, it turns out they're Hot Bodies units: HBS68823
By the way, if you look closely you can see where the coupling ripped allowing the pin to escape.
So I noticed the use of these DCJs required different bearings. They're 1mm wider and the inner diameter is 1mm smaller. Guess I'll need to look into new bearings if I swap them over to something else.
I was looking at the Reflex DCJs as replacements. I just need to determine if I'd be better off with the wider or narrow versions. Any suggestions for a TC6?
Old 02-25-2013, 10:38 AM   #8848
Trader Rating: 49 (100%+)
Might not be a bad idea to PM Christian from reflex and get him to tell you the pros/cons compared to each other. I haven't used both, so I can't say.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 02-25-2013, 10:42 AM   #8849
CristianTabush's Avatar
Tommy, are you using a TC6, or TC6.1? If you are using a 6.1, then go with the narrow version, if it is a 6, then only the wide axles will work.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-25-2013, 10:52 AM   #8850
Tommy R's Avatar
Thanks!! It's a TC6 so I'll pick up the wide version.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
