Like Tree1Likes
Old 02-09-2013, 09:27 PM   #8731
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by goin2drt View Post
i have an old LRP 17.5 and it is time for a new motor. What do you guys recommend for a 17.5 NT motor for our cars.
I heard good things about the Reedy Sonic motors as well but you can't go wrong with a D3, D3.5, RevTech or Speed Passion MMM series. There are a lot of good motors out there but your driving style and track layout can have an effect on determining which works best for you.
YoDog is offline   Reply With Quote
Old 02-10-2013, 07:40 AM   #8732
Trader Rating: 77 (100%+)
What about rotors? Would I need to change out the rotor on any of these when running NT? Lastly of the ones mentioned I like smooth power delivery as you can tell from my dumb questions I am fairly novice.
In off road I run Reedy and LRP motors. Just not sure if those are the best for on road and I am definitely not as good at on road.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 02-10-2013, 02:26 PM   #8733
YoDog's Avatar
Well considering that you are not running at an expert level, you may not need to worry about getting every drop of power available. The stock rotors should do fine but if you want more torque, get the 12.5mm rotor as a tuning aid. Pretty much all the top manufacturers have them available and some even have the larger rotors as an alternate stock model. If you are happy with the Reedy motors, go with that. They work just fine in TC. I'm a Trinity guy myself...to each his own.
Old 02-10-2013, 02:48 PM   #8734
BillPear's Avatar
Send a message via Yahoo to BillPear
FYI, the Reedy's come stock with the 12.5mm rotor, 2 12.3mm rotors are available though.
BillPear is offline   Reply With Quote
Old 02-10-2013, 04:13 PM   #8735
Monsta's Avatar
I though i'd post this here too
I have recently done the Exotek Duel Bellcrank conversion. I now have a huge amount of front end grip.
Unfortunately the car is now excessively Loose Neutral Power, will do a 180 no problem. I have tried softening the rear, stiffening the front (including swaybars), rasing and lowering droop on both ends, lighter oil in the rear gear diff (spool front), lowering roll centre rear – raising the front, rasing the front high and lowering the rear.
Im using sweep 32s on med grip outdoor asphalt
Has anybody else had this issue and were/how you able to sort it out?
*edit
Camber- F -1, R -1.5
castor - 4deg
tow F 1mm, rear 2.5 total
ride hight F 5mm, R5.5mm
droop 2mm all around
Thanks!
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 02-10-2013, 10:28 PM   #8736
mcrcracer's Avatar
Should have gone with the Reflex chassis! Lol
I had the same problem after converting to an RSD chassis, but simply changing (rear) diff from 1300 to 2000 weight solved it.
Someone running the Exotek conversion will have to chime in with a setup for spring rate and mounts
SMC- The best batteries money can buy!
mcrcracer is offline   Reply With Quote
Old 02-11-2013, 10:50 AM   #8737
racing_jason's Avatar
Unfortunately the car is now excessively Loose Neutral Power, will do a 180 no problem. I have tried softening the rear, stiffening the front (including swaybars), rasing and lowering droop on both ends, lighter oil in the rear gear diff (spool front), lowering roll centre rear raising the front, rasing the front high and lowering the rear.
*edit
castor - 4deg
Thanks!
Try making your rear camber link longer or shortening the front.
Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 02-11-2013, 01:02 PM   #8738
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Thumbs up
The results !
This is my car (without shocks for setup), Yesterday I took 2nd on qualify and 1st on A-Final.
I use box setup with a minor changes, and I was surprised with consistent times on Final.
Our track is "parking lot" type and we're using 10.5 boosted.
Originally Posted by wtcc View Post
I don't know to who you are referring to, but the best ways would be:
1. to drill new holes for the standard battery mounts or
2. to make new battery tape taps from cfk which are redesigned for a shorter battery.
In my 4WS I made new holes for the battery mount and milled a new L-formed cfk part. The servo on the other side prevents the battery from leaving the chassis
Team Associated TC6 Thread-tc6.1_01.jpg   Team Associated TC6 Thread-tc6.1_02.jpg   Team Associated TC6 Thread-tc6.1_03.jpg
JQ WE - Alpha Lutz WE - Xpert Servos - AKA
Tekno EB48 - Tekin RX8 - AKA
_________________________
=> BIMA RACING TRACK <==
MiTaller-RC is offline   Reply With Quote
Old 02-11-2013, 04:21 PM   #8739
Trader Rating: 30 (97%+)
ive been racing off-road for 6 years and i just finally bought my first onroad car cant wait!
laceup is offline   Reply With Quote
Old 02-11-2013, 05:31 PM   #8740
98NYFINESTVETTE's Avatar
Ditto: I will find out how my on road skills are next week for the first time. I am nervous, feels like going on a first date. LOL I set the car up by reading the posts on here. Figure this will give me a starting point and then go from there.
SC10 4x4, HPI Baja 5sc, LOSI 5ive T, XO-1, Airplanes & Boats.
We need an Off Road Track in Central Jersey (1/10 & 1/5). When not traveling the country racing in the NMCA, I race off road and on road RC with my son - PRICELESS.
South River Hobby & Bike to the rescue (732) 387-2828.
98NYFINESTVETTE is offline   Reply With Quote
Old 02-12-2013, 09:20 AM   #8741
*edit
castor - 4deg
Thanks!
Lighter oil in the rear diff will only give you more steering. What weight oil are you running? I would suggest trying a thicker oil.
jha07 is offline   Reply With Quote
Old 02-12-2013, 10:11 AM   #8742
kewdawg's Avatar
No. This applies to a front diff. Lighter oil on the rear will create better traction in the rear and can make the car push because it isn't rotating as much.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-12-2013, 10:54 AM   #8743
geeunit1014's Avatar
Actually, lighter rear oil will give you more steering it will make the car go in to the corner harder, and the car will rotate around the rear end more in the middle.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 02-12-2013, 11:28 AM   #8744
kewdawg's Avatar
This sounds like the "diffing out" effect, where the diff is too loose and not able to transfer power to the wheels properly.
Quinn Moon
Old 02-12-2013, 11:38 AM   #8745
DesertRat's Avatar
The engineers nightmare: Increasing the diff oil weight can make it worse, make it better, or stay the same.
Increasing the diff fluid weight in my car made the back end slightly more lose.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
