Old 02-01-2013, 01:55 PM   #8686
Originally Posted by silvalis View Post
I just started putting together the shocks in my WC kit (first assoc kit!) and have noticed this weird ribbing on one of the shock shafts. It's causing a slight binding.
Has anyone else come across something like this?
I have seen this on one of my two kits that I have built this year. It didn't cause any binding in my case but if you find it is preventing your shock from moving freely you could use some metal polish and polish the shaft ever so gently.
This is what I use: http://mobile.rcdepot.ca/Product.aspx?ProductID=136271
My friend did up an instructional video on how we polish the shock shafts/hinge pins on our off-road vehicles: http://www.youtube.com/watch?v=OKLRitquqz8
Hope this helps.
-Kane
Kane-o is offline   Reply With Quote
Old 02-01-2013, 10:37 PM   #8687
JFuel11's Avatar
Trader Rating: 137 (100%+)
Default Reflex TC6 Springs
Does anyone know where I could find a set of reflex springs that has the silvers, blues and Yellows in it? Seems like the kit they have on the website is all heavier spring rates now.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
Team Associated - Reedy - Airtronics - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - B-RacingHobbies Your Official Airtronics and G-Force Dealer
JFuel11 is offline   Reply With Quote
Old 02-02-2013, 01:29 AM   #8688
wtcc's Avatar
You can replace the silver an blue springs with the actual green and red springs of the black series (red is sold separatly).
Try to get the 13.5 yellow springs used. These are one of my favourites when the traction is up on raceday! It is a shame that these fell out of the spring range Christian offers. But he is very customer orientated so there is a good chance that he will make some more
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 02-02-2013, 01:43 AM   #8689
CristianTabush's Avatar
We still have yellows in stock. Green and blue are very similar green being slightly softer. The only spring that is no longer available is the silver spring.
However, you might want to try superior hobbies to see if they have any of the blues and silvers left, last time I talked to them they had some in stock.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-02-2013, 03:11 AM   #8690
wtcc's Avatar
It is a little confusing with the yellow springs as their rate is 13.5 in the RSD6 tech section and 12.x in the shop...
AE / Reedy / RSD
Old 02-02-2013, 06:54 AM   #8691
20967's Avatar
Hi, Cristian Enrico From Italy.
The RSD6 Aluminum Floating Servo Mount fit in original TC6 chassis with no any additional works or not?
Any help is appreciated.
This is my new UpGrade for TC6.
Enry
20967 is offline   Reply With Quote
Old 02-02-2013, 08:29 AM   #8692
Enry
No, it will not be a straight fit. You must drill 1 hole on the chassis.
Old 02-02-2013, 11:12 AM   #8693
20967's Avatar
Thks Cristian for replay.
Enry
Old 02-02-2013, 02:01 PM   #8694
wtcc's Avatar
I want to share my TC6 conversation. It includes the possibility to use shorty lipos, four wheel steering, centered weight (motor moved forward), lower weight center (TShox, short bulkhead clamps, lower shock tower), narrow chassis...I think thats all:
AE / Reedy / RSD
Old 02-02-2013, 03:00 PM   #8695
DesertRat's Avatar
I hate you so much right now. You literally did everything I have wanted to try on a touring car in one shot, and now I must ask... who makes that four wheel steer setup or did you do it yourself?
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 02-02-2013, 03:02 PM   #8696
DUDE!
Are you lost mind?????
OK, it is avesome! How it drive?????????
Results and video of moving parts, please!!!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-02-2013, 03:12 PM   #8697
wtcc's Avatar
I take that as a compliment
Everything done by myself. The four wheel steering conversation is quite easy. Use the front suspension parts for the rear and buy another steering arm plus the long turnbuckle and a double sided servoarm. Now the hard part: You need to move the spur gear bulkheads forward to make space for the steeringarm. If you do this your belts wont fit anymore. So you need to get two new ones. The lower chassis needs new holes for the moved spurgearbulkhead. The top plate cannot be used anymore. A new one is needed to include the second steering arm and the new position of the spur. Sounds a lot, but only the new topplate will cause some real costs.
If you are interested in a build I give you my CAD drawings and all information you need.
AE / Reedy / RSD
Old 02-02-2013, 03:16 PM   #8698
Very good very good
But I'm going to drop that racing class in 2 months.
I WAIT FOR YOUR RESULTS AND VIDEOS
Michal Abramowicz
Old 02-03-2013, 09:18 AM   #8699
trigger's Avatar
Received my RSD6.2 in the mail last night and converted my old tc6. The rsd chassis is a quality piece of carbon! Switched every thing over and went smooth. The bell crank went on nicely and Rsd includes the longer turn buckle so nothing else is required for the conversion. I also installed the newer shock towers and bearing caps. Aside from the non tc6.1 arms and suspension. This tc6 is totally refreshed.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 02-03-2013, 12:52 PM   #8700
wtcc's Avatar
I made a short video of the steering function of my 4WS today:
http://www.youtube.com/watch?v=GEUVX...ature=youtu.be
The car was good to drive, with a lovely inital turn in. It didn't like the 110% driving. Within the 105% it was incredibly agile. The direction change from left to right and vise versa is lightning fast!
The actual design didn't show any weakness even though I had some meetings with the wall. So I am happy and will work on the setup in the coming week (because the car also is like riding a wild horse and needs full attention). I could go the same laptimes with other drivers (same motor turns). Right now with a "normal" touring car setup I have the feeling of understeer into the corner and toooo much steering in the middle and out of it. Maybe something I can easily adjust on my remote, but not sure.
The Tshox worked good and made no trouble, very smooth.
AE / Reedy / RSD
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
