Like Tree1Likes
Old 01-26-2013, 04:14 AM   #8656
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Still using the stock Turnbuckle Eyelets (ASC31305) paired with Associated Ti-Nitride Ball Studs on suspension, producing a very free suspension.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 01-26-2013, 04:53 AM   #8657
RCW
Trader Rating: 16 (100%+)
When a setup sheet has 2mm for a droop setting, what does that mean?
Must be a differant way of measuring droop, just not sure where that is measurement is taken.
RCW is offline   Reply With Quote
Old 01-26-2013, 11:59 AM   #8658
It means that when the car is on it's wheels at ride height, race ready, there is 2mm of up travel. As in, you can lift the car up 2mm before the tires leave the ground. This is a much better way of measuring droop than using the gauge that came with the kit.
jha07 is offline   Reply With Quote
Old 01-26-2013, 01:11 PM   #8659
CristianTabush's Avatar
Not quite that, but close. It is actually 2mm of uptravel before the shocks stop extending. Due to the nature of rubber tires, if you adjust them to only pick up after 2mm of up travel , you end up with actual less droop than 2mm of uptravel. Tires typically have about 1-2mm of "sag" that add to the effect of having more droop.
I learned this the hard way... After trying many set-ups of 3mm uptravel up front and 2mm rear, I gave up and started using droop gauges. After I found out how it was actually set, then I realized that I was putting like 1-2mm less uptravel than what the set-ups call for.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 01-26-2013, 02:46 PM   #8660
RCW
So, what is the best way to do this? Use a set of wheels without tires mounted on them?
Old 01-26-2013, 03:34 PM   #8661
JustWill75's Avatar
Send a message via AIM to JustWill75
yeah whats the answer????
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-26-2013, 03:58 PM   #8662
Everyone has a different method. I find it easiest by using aluminum set up wheels. This allows you to do it with a ride height gauge and measuring the 2mm higher than your ride height when the set up wheel picks up it's set at 2mm over.
Another way is the eye ball way. Measure your ride height and set it where you want it. Then pick up the car and observe the shock shaft. When it stops moving, look at the ride height gauge. The tires will still be touching the ground, but the shock will no longer extend. Set the droop to the desired point where it gives you the ride height you want with the shock fully extended. To find this out measure the ride height when the car is picked up and shock fully extended, for example 8mm and then your resting ride height, ex:5mm subtract one number from the other and you get your droop over ride height. In this case, it would be 3mm. The best way to do this is to set each corner of the car individually by placing the ride height gauge under each of the side you are doing at a time.
Hope the info helps.
Old 01-26-2013, 04:17 PM   #8663
Cristian,
Are you guys going to stock the TC6 hard bumper again at all??
I'm chasing one that's wider and a little harder than the stock item.
RSD Spec TC6.1, Tekin RS, MMM, Sav÷x, Sorex.
Steve89 is offline   Reply With Quote
Old 01-26-2013, 05:24 PM   #8664
Not sure when. I am looking for some different options right now. I want to, but have to work out a couple of things. We'll have something more definitive in a few weeks after spring festival in China.
Old 01-26-2013, 08:00 PM   #8665
No worries, look forward to seeing what you come back with.
Old 01-26-2013, 09:13 PM   #8666
I see the TC6 has been discontinued is the 7 almost out?
Dieselman1220 is offline   Reply With Quote
Old 01-26-2013, 09:16 PM   #8667
TC6.1WC just came out slow 'er down man. Probably won't see the 7 kit for a bit.
Night is offline   Reply With Quote
Old 01-27-2013, 01:32 PM   #8668
Rockin G's Avatar
Deleted....it was a dumb question anyways that I eventually found the answer for.
Rockin G is offline   Reply With Quote
Old 01-27-2013, 06:40 PM   #8669
rbarciko's Avatar
hi guys,
is anyone running the TC6.1 front spool in the TC6.0 chassis?
it seems to be 3-4mm widder than the TC6 front spool, so it doesn't fit , even though it is listed on the TC6 page as a spare part:
http://www.teamassociated.com/parts/details/31339/
-== Robert Barcikowski ==-
TFTR TC6 F104v2 RC Parts Search
rbarciko is offline   Reply With Quote
Old 01-29-2013, 12:49 PM   #8670
Crashmaster's Avatar
Default Rear Toe
Hi guys,
Just putting a setup on my car from Olly Jefferies and got a question on the rear toe.
On the setup sheet the forward mount has 0mm spacing and the rear 2.5mm and a total rear toe of 3.1 deg - can anyone confirm this is with the 0 degree inserts in the hub?
I'm assuming 2.5mm is slightly thicker than a 2 deg and 1deg shim together but haven't got an callipers (working!) to check!
Dan
Crashmaster is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
